Page 561 of 854 FirstFirst ... 61461511551556557558559560561562563564565566571611661 ... LastLast
Results 8,401 to 8,415 of 12801
  1. #8401
    May 2011
    While 8.0 loader starts there is info "Failed 4" anybody knows what is it?
  2. #8402
    Jun 2019
    Only it turned out that it was successful. Strange and works, that's why my question.
  3. #8403
    Mar 2018
    Quote Originally Posted by anubis14 View Post
    Zrobiłem VCDSLoader_v8.0 bez 12V. Czy mogą być jakieś błędy?
    I did VCDSLoader_v8.0 without 12V. And can there be any errors?
    Thank you very much :Kolimer Zrobiłem VCDSLoader_v8.0 bez 12V. Czy mogą być jakieś błędy?
    If the LED on your scanner is lit after connecting to the USB port, then you have the atmega162 powered by a cable and not a 7805 transistor (or other converter).
    And please do not forget to upload photos of your board from two sides so the description of questions will be faster and clearer.
    or maybe I didn’t understand you correctly and you meant that they didn’t flash it with eeprom, but just changed the loader
  4. #8404
    EU
    Quote Originally Posted by psgpol View Post
    Can I ask for a link to 19.6 version which works with last 8.0 loader or its still same as version from RTech website?
    You want too much, loader released only yesterday.
    There are at least 4x 19.6 english releases: May 31, June 6, June 10, June 11.
    Most changes are only in vcds.exe
    Don't quote this post.
    Does anyone have or know a cheap ecu which shows as unsupported vehicle message? MY2019 could be expensive Need it for loader testing.
  5. #8405
    Jun 2019
    I have run VAGCOM_HWType.exe, no success, running VAGCOM_EEWriteLang.exe. Success on polish - AKPI success, n po
  6. #8406
    Aug 2018
    Should i have ftdi serial number RT000001 on interface to get 7.2 loader and vcds 18.9 working? Serial is disabled by default and get "interface not found" and led is acting weird. HWtype shows that already have 1.96 flash. It should work without reflash?
    edit: changed ftdi serial to RT00001 and now 18.9 vcds say "interface found, not plugged into car" and when plugged to car vcds say "interface not found"
  7. #8407
    Jan 2017
    VCDS version 19.6.0? 32/64 bit?
  8. #8408
    Jan 2018
    PL
    Quote Originally Posted by engycz View Post
    18.9.1 AKP 32bit
  9. #8409
    May 2011
    yes i tested on 18.9.1 AKP and it works OK,
    i just saw that "Failed 4" but nothing bad happen with 18.9.1akp
    is it because of 32bit version ?
  10. #8410
    Jul 2017
    Here is a link to the installation file 19.6.0.2 for NEC, ARM ( with FW-1.96 only ) and all the others with ATMEL
    new :
    http://ge.tt/9R9AXZw2
    Do not require flashing. As a bonus CAN commands sniffer.
  11. The Following 11 Users Say Thank You to BASi77 For This Useful Post:
    alexm1 (12th June, 2019), AYD (15th June, 2019), Barm76 (24th September, 2019), eLKa (6th July, 2019), kaalis (12th June, 2019), lemta (13th June, 2019), Mario6 (12th June, 2019), miouser (15th June, 2019), Roma77 (12th June, 2019), tigex (19th July, 2019), tr3ce13 (13th June, 2019)
  12. #8411
    May 2018
    Brazil
    Quote Originally Posted by BASi77 View Post
    Here is a link to the installation file 19.6.0 for NEC, ARM and all the others with FW-1.96 only.
    http://www.ge.tt/8HaDSZw2
    The link is down. May I have another upload option?
    Thks a lot
  13. #8412
    Jul 2016
    Vilnius
    The Dictator has just removed the link moments ago. Could you please reupload.
    He should be busy fixing problems in latest 19.6 release instead...
    * MK100
  14. The Following 3 Users Say Thank You to hid3 For This Useful Post:
    alexm1 (12th June, 2019), kaalis (12th June, 2019), pablobrsp (12th June, 2019)
  15. #8413
    Jul 2017
    NEC device
    Soft from post #8417
    CAN Sniffer
  16. The Following 4 Users Say Thank You to BASi77 For This Useful Post:
    alexm1 (12th June, 2019), Gyula84 (27th June, 2019), kaalis (12th June, 2019), miouser (15th June, 2019)
  17. #8414
    Member lemta's Avatar
    Jun 2012
    new :
    http://www.mediafire.com/file/q1qqel....6.0c.zip/file
    I'm not sure if I am understanding this correctly. Are you saying this version works on people that have ARM or NEC chip instead of the Atmel162 chip?
    So I have a Hex V2 with ARM chip that came with 17.1.3 software (without loader). Will this version work without flash programming?
    Once this v19.6.0c is installed is it possible to revert back to old software if needed? Many thanks for the answers.
  18. #8415
    Jul 2016
    Vilnius
    Quote Originally Posted by lemta View Post
    You check it and report back
    Unfortunatey we don't own crappy stuff so no possibilities to check...
    * MK100
