Results 1 to 4 of 4
    Jan 2016
    ROMANIA
    Default Citroen C3 SAGEM ECU S2PM-381 virgin or PIN write in eeprom
    Hello, I have a Citroen C3 without original ECU, I bought a second hand ECU and read the eeprom 95080 (I attach the file from SH ECU). What is the best way to start the car? I read that this ECU can be done virgin (I do not have a solution), or modify manual the file and change the pin code (I do not have the pin code from SH ECU, I can read the car PIN from BSI).
    Need help, thanks!
  2. The Following User Says Thank You to mihai cristian For This Useful Post:
    majster10 (18th February, 2022)
  3. #2
    Jan 2016
    ROMANIA
    2VTS is the pin from SH ECU, if I have the pin from BSI and write it by hand in sh eeprom the car will start?
  4. The Following User Says Thank You to mihai cristian For This Useful Post:
  5. #3
    rafal's Avatar
    UK - PL
    write this file and recode by lexia with pin from bsi
    need help
    now my goal is to buy xp-005
    who will help?
  6. The Following 3 Users Say Thank You to rafal For This Useful Post:
    ali kaptan (5th February, 2022), mihai cristian (28th September, 2020), yojuzanew (2nd December, 2020)
  7. #4
    Jan 2016
    ROMANIA
    Quote Originally Posted by rafal View Post
    I will try tomorow, thanks!
