Results 1 to 15 of 17
    Germany
    Default VW Radio Code BNO881
    Hello, i need my radio code for an Volksagen BNO 881 Radio
    dump is in attachment
    Thank you in advance and kind regards
    Dekster's Avatar
    Dec 2012
    POLAND
    Quote Originally Posted by mm04kk View Post
    .......... 0420
  3. The Following 3 Users Say Thank You to Dekster For This Useful Post:
    bogege (6th April, 2020), masterskay62 (5th April, 2020), mm04kk (5th April, 2020)
    Germany
    sorry 0420 is wrong
    Germany
    if you dont get the code do you can make it off in dump that i can write it
    Bulgaria
    maybe 0458 !??
  7. The Following 2 Users Say Thank You to bogege For This Useful Post:
  8. #6
    Germany
    0458 is also wrong
  9. #7
    Dekster's Avatar
    Dec 2012
    POLAND
    sorry 0420 is wrong
    VWZ1Z7E5407994
    1K0 035 198A
    Code is: 0420
    100% correct
  10. The Following 2 Users Say Thank You to Dekster For This Useful Post:
    mm04kk (5th April, 2020), nigrou (5th April, 2020)
  11. #8
    Bulgaria
    0458 is also wrong
    I'm sorry try 0460
  12. The Following User Says Thank You to bogege For This Useful Post:
  13. #9
    nigrou's Avatar
    Dec 2010
    algeria mascara
    try code 1810
  14. The Following 2 Users Say Thank You to nigrou For This Useful Post:
    bogege (5th April, 2020), mm04kk (5th April, 2020)
  15. #10
    Bulgaria
    It is also possible
  16. The Following 2 Users Say Thank You to bogege For This Useful Post:
  17. #11
    Germany
    hello thank you all very much i have tried the first twoo codes and they dont work then i have writed this dump which i found on google to the radio now the radio is without code.
    It works fine now.
    Thank you all for your help
  18. #12
    Raimax's Avatar
    Nov 2013
    LT
    It works fine now.
    I don't think it will work for you for a long time without code
    If you don't like it * close your eyes
    --- Geros dienos ! ---
  19. The Following User Says Thank You to Raimax For This Useful Post:
  20. #13
    Germany
    Why, will the radio makes problem after some time? I dont know i try it first time now. The radio works it comes on directly and dont need code and works everything. Do you have problem before with this file?
    Kind regards
  21. #14
    Raimax's Avatar
    Nov 2013
    LT
    Try to keep the radio without power for longer. I never tried this file because i didn't need it
  22. #15
    Germany
    Thank you very much, if he needs code after some time i will write the original file back and try the codes that are posted here.
    I also found a file where the code is 1574 if the codes from here dont work i will write this file and try this code
