Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
  1. #16
    Nov 2017
    revivifie polie d'arbre a cam et je suis sur qui l ya de fuit d'air admission quelque par( papillion )
  2. #17
    Jan 2018
    Default how did you solve the timing issue ??
    Quote Originally Posted by wodorof View Post
    i have problem with 2003 petrol megane,
    cold engine does not idle, starts and stops immediately,
    when i put foot on acc pedal engine works at higher revs, some times when engine is warm and when i lower rpms slowly, engine idles, but it is still quite unstable
    every sensor looks fine on diagnostics, i only have df199 cam shaft sensor error
    i changed sensor but error stays and there is no improvement.
    Thanks in advance!
    [SOLVED]!
    timing was wrong, due to pushstart belt jumped two teeth,
    and it caused whole problem
    i have exact the same problem , except that the code appears and disappears on its own , i have this problem after changing the timing belt in unprofessional garage .
    how can i set the timing again >?? because you mentioned above that che camshafts were horizontal , and later on you did confirmed that there is something wrong with the timing .
    please help
