Results 1 to 15 of 18
    Oct 2017
    Default conection MPPS V18 to zafira Y2.2DTR PSG16
    Sorry for my English, but.
    Somebody can say me, how can i need conect the MPPS V18 to the PSG16 to read ECU for remap?
    the color of wires i need conect, between the MPPS and the wires of near the batery.
    johak's Avatar
  3. The Following 3 Users Say Thank You to johak For This Useful Post:
    HeXeN (4th May, 2020), osobuque1 (5th November, 2017), raskolnikov1975 (17th November, 2017)
    May 2014
    LIthuania
    here you go mate made by myself its really easy just find can wires in the loom near the battery they are green and white in black pvc ,good luck mate
  5. The Following 8 Users Say Thank You to tiugrikas For This Useful Post:
    Col19 (24th December, 2019), danielif (10th March, 2018), HeXeN (4th May, 2020), impuls002 (7th July, 2018), mancioks (1st August, 2018), osobuque1 (5th November, 2017), SALAS (10th December, 2017), smirnoff_rules (17th November, 2017)
  6. #4
    Oct 2017
    I only need to take the black thick wire, cut and connect the MPPS wires?
    in the black thick wire the Green wire is CAN H and the White wire is CAN L?
    I need cut all the wire, or only doing a small hole in the green and white cables to connect the wires itīs ok?
    May 2014
    LIthuania
    personally i cut wires without cutting wires i didnt try yet .and yes white and green wires for can
  8. The Following User Says Thank You to tiugrikas For This Useful Post:
  9. #6
    Oct 2017
    Finaly i didn’t need cut all the wires, only doing a small hole in the wires to conect the MPPS it’s ok.
  10. #7
    Oct 2017
    somebody can say me, what happened with my readed file?
    I think is not all the ECU is readed.
    55352863.rar
    Iīm trying to read with the MPPS V21, but something is wrong.
  11. #8
    carbon7319's Avatar
    Aug 2011
    Macedonia
    Why you think that is not readed ok ?
  12. The Following User Says Thank You to carbon7319 For This Useful Post:
    prevozsa (14th May, 2020)
  13. #9
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    We try to tune it, but its missing few maps..
    DSG TUNING
    File Service
  14. #10
    mancioks's Avatar
    Feb 2017
    Germany
    what maps missing?
  15. #11
    Oct 2017
    hi,
    I get some files remaped from one vectra bertone Y2.2DTR, and PSG16, but I open the files and the maps there arenīt in the same place like in my readed file.
    I know isnīt good to write in my car the file from other car.
    What can I do to check that file and transform for my car?
  16. #12
    mancioks's Avatar
    Feb 2017
    Germany
    Quote Originally Posted by osobuque1 View Post
    hi,
    Take yours file and modified one and compare them in winols
    Put modifications to your file and write
  17. The Following User Says Thank You to mancioks For This Useful Post:
    osobuque1 (17th November, 2017)
  18. #13
    Oct 2017
    I compare the first map and in the driver wish the range is not the same, in x i have the range since 82 till 8192 and the remaped have since 0 till 10000. Can I cange this parameters?, because when iīm going to change the winols alert me saying "Protected area is being changed the contents of the 0X820A is to be changed, every though this address is not be covered by any checksum áreas.
    Can I change, without problems them writing?
    may be i can change only the map parameters, but not the memory place in the ecu?
  19. #14
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    wonder if your problem was not cutting the can wires and you didnt get full read ?
  20. #15
    mancioks's Avatar
    Feb 2017
    Germany
    You can change the axis, but after all you have to do checksum. If u use mpps18 it should do it for you.
  21. The Following User Says Thank You to mancioks For This Useful Post:
    osobuque1 (18th November, 2017)
