Results 1 to 14 of 14
Thread: passat tdi 105
    Autotecno2006's Avatar
    Aug 2009
    Default passat tdi 105
    hi all, need help/advice, have 2005 passat tdi 105HP, came in running badly, worn cam & broken buckets. all repleaced with new parts,now no dtc`s. Problem is NO POWER & slow to accelrate, also takes extra cranks to start when hot, I have attached ecu file with with MPPS, would appricate if someone could give a look & advise, Regards P.
    florinyes's Avatar
    Dec 2009
    London Middlesex
    Also had a similar one with worn buckets..customer wingging now after head gasket skim and new buckets no power at over 60 mph or up hill.
    Is there anything in the map that causes this?? Very difficult to prove cars been pulling away OK before repaires as car was running quite bad..
    Whatever seems impossible is just not yet important enough.
    levisdj's Avatar
    Apr 2010
    EcuLand
    The air flow meter usually causes power loss.
    Dec 2010
    Quote Originally Posted by Autotecno2006 View Post
    Hello
    File is 100% original. So no problem from this side.
    greetings,
    filecloud
    Aug 2009
    Hi all, Thanks Filecloud for looking at file, i have another Passat coming tomorrow so will be able to play with both. report tomorrow, P.
    Jun 2010
    i don't have the permission for download the map, but you change the maf sensor and the car have a good response... for the problem an hot start, i know the maps to modified!!
    Mar 2010
    pro nowt to do with ecu more like air flow meter or summet
    Jun 2010
    this file for you, modified for good hot start
    Feb 2010
    Romania
    Default Same hot start problem
    Hello I have a seme hot strat problem with a passat 2006 1,9 tdi BKC engine 0281 012 742
    Someone could help me?
    thanks...
    Sep 2011
    derventa,BiH
    Default Re: hot start problem
    I think that I can help you.Please,send me SW(four digits in the second window after identification).
    Regards!
  11. #11
    Feb 2010
    Romania
    Carsoftware can modify some content but this is an 2 mb content.carsoftware can do 1 mb....How can i use that function?
    Any idea..?
    is edc16U31
    The sw 1037377575
  12. #12
    monitel_service's Avatar
    Sep 2009
    ROMANIA
    ILLESTIBOR your file with hot start problem
  13. #13
    Belfast, NI
    Log with vcds and post logs, full throttle high gear most of rev range.
  14. #14
    Aug 2009
    Yes, ... Log block 3, 8, and 11 with vagcom and post up...
