Page 1 of 2 12 LastLast
Results 1 to 15 of 28
    Default Gilera, piaggio Vespa bikes Engine ECU Marelli
    I have a Vespa motor and the key is to lose
    I have read the dump ST10F269 144 pin gave a straightforward solution that can be programmed or transplonder to immo off
    Vespa 250
    5x80fux8g
    cm078201
    32 mIu1.e0
    Default dump
    Device: ST10F269-T3 - 144 pin TQFP
    256/262144/327680
  3. The Following 2 Users Say Thank You to selim For This Useful Post:
    arti1 (23rd August, 2021), Geekey (18th November, 2020)
    Jun 2009
    i do by hand i do not have programmer it must be
    5f 00 00 8d d2 80 56 7d key 1
    5f 00 00 af 82 80 56 7d key 2
    if not work try swap
    like
    key 1 5f 00 00 d2 8d 80 56 7d you will find it not worry
  5. The Following User Says Thank You to gadroulll For This Useful Post:
  6. #4
    gepakg's Avatar
    Feb 2010
    Serbia
    here is logic for t5 write as temic 11: 7D5F00008056D28D
    work 100%
    regards Gepa
    Quote Originally Posted by selim View Post
    256/262144/327680
  7. The Following 4 Users Say Thank You to gepakg For This Useful Post:
    auto_russia (1st April, 2013), Geekey (18th November, 2020), lion0304 (13th April, 2015), motorbike59 (21st November, 2020)
  8. #5
    Thank you thank you thank you "gepakg" This combination is ok ...., But thanks to the "gadroulll" without you this would not able to solve
  9. #6
    Apr 2010
    Default piagio MP3 250ccm
    Hello!Can anyone help with this file I need to program key for Piaggio MP3.Thanks
  10. #7
    Apr 2010
    Piagio dump
  11. #8
    gepakg's Avatar
    Feb 2010
    Serbia
    this type of ECU have external immo,keys not in st10f269
    regards Gepa
    Quote Originally Posted by igor6997 View Post
    Piagio dump
  12. The Following User Says Thank You to gepakg For This Useful Post:
  13. #9
    Apr 2010
    Is there any solution to make virgin ECU or immo...
  14. #10
    Jan 2010
    italia roma
    Default piagio bevery 250
    piagio bevery moto.rar
    pls. help me transponder temic 11
  15. #11
    gepakg's Avatar
    Feb 2010
    Serbia
    here is master key: 7D 5F 00 00 80 AE 28 B5
    regards Gepa
    Quote Originally Posted by viorelloj View Post
  16. The Following User Says Thank You to gepakg For This Useful Post:
  17. #12
    Jan 2010
    italia roma
    ok
    works perfectly
    strong
  18. #13
    Nov 2013
    UK
    How did you read ST10F269?
    Did you desolder or have pinout?
  19. #14
    alclot's Avatar
    Sep 2009
    Melee Island
    hi mates,
    I have piagio x7 125cc with immo problem. I have one key and I think it is ok but bike no work. Can anyone help me with immo off or other solution?
    Thanks in advance
  20. #15
    Oct 2016
    Default x7
    Hello
    please write this dump and start to moto with org. key
  21. The Following User Says Thank You to datagaraj For This Useful Post:
    alclot (19th November, 2018)
