Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 73
Thread: Flat Earth
  1. #46
    Meat-Head's Avatar
    Social distancing has been particularly stressful for the Flat Earth Society.They fear such measures will push someone over the edge.
  2. The Following 3 Users Say Thank You to Meat-Head For This Useful Post:
    darrenhyland (23rd April, 2021), nara (23rd January, 2021), Stelaras26 (30th June, 2021)
  3. #47
    Nov 2017
    Dobruja
    It remembers me that bit of animation between Bugs Bunny and Christopher Columb...
    https://youtu.be/TBv3_0j0y_4
  4. The Following User Says Thank You to volodin69 For This Useful Post:
    nara (6th September, 2021)
  5. #48
    Meat-Head's Avatar
    If someone can rip this video and upload great
    WITCH
    intresting, shows the world is round or this guy a scam artist
    https://mobile.twitter.com/UniverCur...06704875147264
    really is worth watching
  6. The Following User Says Thank You to Meat-Head For This Useful Post:
  7. #49
    nara's Avatar
    May 2008
    Home
    That's not fair Meaty! I don't do Twatter.
  8. #50
    Meat-Head's Avatar
    Quote Originally Posted by nara View Post
    I dont do INFERIOR websites, but I joined one to LEECH something. Not able
    to name site, as only know it is an INFERIOR site, that dispite been 10 years older than DK,
    was still a copy of DK.
    link should still work unless deleted by someone at other end
  9. #51
    V.I.P. VIC
    Mjolinor's Avatar
    Jan 2009
    Burnley Vicshire
    Quote Originally Posted by Meat-Head View Post
    WITCH
    Of course you have to make the assumption that the sun is so far away as to make the rays coming from it almost parallel. If the sun is much closer then the same happens with a flat earth.
  10. #52
    Top Poster luisfm's Avatar
    Feb 2013
  11. #53
    Meat-Head's Avatar
  12. #54
    nara's Avatar
    May 2008
    Home
    I lost the will to live after a while. What exactly was it trying to say? emotions11.gif
  13. #55
    nbtechnic's Avatar
    Jan 2016
    For me, I understand that all the rebuttals they give make no sense, they are just words to contradict other words.
    I became convinced that the earth is flat,
    especially since I saw the nasa green screens,
    with its giant swimming pool in which the iss is located,
    since I saw bubbles in space with astronauts,
    since I saw the first astronauts put on a bad face when they returned from the trip to the moon,
    since the boats which disappeared behind the horizon of the curvature of the earth, reappeared thanks to a telescope,
    I stop here the list is too long...
  14. #56
    nbtechnic's Avatar
    Jan 2016
    https://www.digital-kaos.co.uk/forum...207-Flat-Earth
    I'm surprised and happy to see that a topic that started in May 2012 is still active 10 years later
    I can say that I have years of catching up to do,
  15. #57
    May 2022
    Default flat is real
    flat flat flat
    Quote Originally Posted by GastonJ View Post
    I've not seen this mentioned on here, but I could be wrong.
    I've just been reading the Flat Earth Wiki. I won't bore you with all the details since you can all read, otherwise you wouldn't be reading this - unless you're all in a conspiracy to fool everyone into think your can read when you can't of course. Anyway it's well worth a read, especially for conspiracy nuts, which appears to be the case in this forum. Main site
    The Flat Earth Wiki
    and a few FAQ's below for those who conspire not to read for themselves, as some users do, or don't as the case may be
    Q: "Why doesn't water run off the Earth?"
    A: You may notice that in this model, Antarctica is a great ring around the disk. This stops the water from escaping. Antarctica as a continent does not exist except in the Wilmore model.
    Q : "Why is the North pole colder than the equator?"
    A: The sun circles over the equator, so the poles do not receive the same intensity of light.
    Q: "What about Lunar Eclipses?"
    A: A celestial body, known as the antimoon, passes between the sun and moon. This projects a shadow upon the moon.
    Q: "How come the travel time by air from South America to New Zealand, via the polar route, is SHORTER than the travel time going North first and then South again?"
    A: The airline pilots are guided by their GPS. Remember that satellites do not exist. The replacement data given from pseudolites deliberately throwing distorting all the paths to make it the flights take different times. The curvature of these paths can add or subtract great distances without the overall turning being obvious to someone traveling it.
    Q: "If you go directly south won't you eventually fall off the edge of the Earth?"
    A: Yes, you will. In order to use this fact as proof you need to record a video of someone flying directly south around the world without falling off the edge. Furthermore you need to prove that your navigational equipment allows you to travel directly south without deviating.
    Q: "What about the stars, sun and moon and other planets? Are they flat too? What are they made of?"
    A: The sun and moon, each 32 miles in diameter, rotate at a height of 3,000 miles above sea level. As they are spotlights, they only illuminate certain places. This explains why there are nights and days on Earth. The stars are at a height of 3,100 miles above sea level, which is as far as from San Francisco to Boston. In the dark energy model, the celestial bodies are spherical and are made of ordinary matter. These spheres are being held above the Earth by DE.
    Q: "What is underneath the Earth?"
    A: This is unknown. Some believe it to be just rocks, others believe the Earth rests on the back of four elephants and a turtle.
    .... I reckon the Turtles name is Atuin...
    Q: "Why do the all the world Governments say the Earth is round?"
    A: It's a conspiracy......
    This is my favorite:
    Q: "What about satellites? How do they orbit the Earth?"
    A: Since sustained spaceflight is not possible, satellites cannot orbit the Earth. The signals we supposedly receive from them are either broadcast from towers or any number of possible pseudolites. However, temporary space-flight is possible.
    If that's the case, and I get caught hacking satellite TV (as if anyone would ever do that), can I claim that since teh Earth is not flat and has no satellites then I cannot possibly be guilty of such an offence????
    Anyway, have fun
  16. #58
    nara's Avatar
    May 2008
    Home
    Could this thread please be renamed “Looney Tunes”.
  17. #59
    nbtechnic's Avatar
    Jan 2016
    It's understandable that cognitive dissonance gets too strong when you don't want to examine the evidence of an inescapable reality.
    it's so much easier to keep dreaming of going into space, but it's only a childhood dream and it will remain so for all of us.
    Alas, the indoctrination of space began for us from the TV screen, then at school, then again in science fiction films.
    It's easier to keep lying to people than to tell them the truth, they'll never believe you.
    NASA has been lying to us since its creation, the space was built in hollywood studios, ask these three gentlemen Wald Disney, Warner Von Braum and Stanley Kubrick.
    Do not look for the truth on youtube, it censored everything that was positive to the flat earth, to leave only what is derisory.
    The earth is a circular flat surface, surrounded by a wall of ice.
    Admiral E.BIRD to explore the south several times in the 50s,
    on his return from the 4th voyage the states prohibited access to the south to all, boat, plane.
    Total control by the military of the countries that have signed the Antarctic Treaty.
    The Antarctic Treaty was signed in Washington on December 1, 1959
    by the twelve countries whose scientists had carried out activities in and around Antarctica during the International Geophysical Year 1957-1958.
    NASA was created on July 29, 1958, coincidentally?
    What do they want hidden in the south?
  18. #60
    nara's Avatar
    May 2008
    Home
    Quote Originally Posted by nbtechnic View Post
    It's understandable that cognitive dissonance gets too strong when you don't want to examine the evidence of an inescapable reality. it's so much easier to keep dreaming of going into space, but it's only a childhood dream and it will remain so for all of us. Alas, the indoctrination of space began for us from the TV screen, then at school, then again in science fiction films...etc...etc...etc...yadda...yadda...yadda
    Run that by me again. Preferably with paragraphs to facilitate comprehension.
