Nobody!
Hi everybody!
Before! i can't synchron DME and EWS in my bmw! So car can't start!!!But i put a new file in DME, so After that, synchroniuos between DME/EWS is now possible, the engine cranck but no fire and no check engine in the dash when i put on ignition!!!The electrical pomp not run!!!
Can someone help me to solve this problem!!!
This is the new file!!!BMW 0261204420 ID-OK.rar
THanks
Nobody!
immo off original
Hi everybody!!!!Thanks about all reply!!!
I tell you the problem here:
After remplacing the fuel gauge, the car has "Short circuit" so car can't start!I program key +ews3 and i remplace wiht new dash so car can start during 15 minutes, after that i restart car and them the problem appear: car can't crank, can't start!!!!I synchron DME/EWS with PAsoft, but impossible, i received this errors:
Error1 with PAsoft:
error2 with PAsoftroblem in adaptation DME/EWS
Then i remplace file in DME with an other new file that i found in digitale kaos(because i guess that the new dash destroy my originale file!!!)!So adaptation between DME/EWS is OK!!!car can crank with this other new file but car still can't start!!!I don't know if it's a problem about the new file( VIN,....)???
Here the new errors:
The errors is Code 7C(124) battery main relay!!!
the pump isn't work and check engine turn off!
The VIN of my Originale file is:WBAAL31070AY04296
The VIN of the new file is:WBAAL31070AY04286
I ask to everybody if my solution is right, i'll try now to search a new file to EWS(EWS corresponding to the new full falsh in DME!!!)
Thanks everybody!!!
Here the new file(car can cranck with it but still can't no start!!!! And if someone else has another good originale file to this ecu thanks to share to me!!!
Errors code:
The pump isn't work and check engine turn off!
Thanks!!!new flash bmw e46.rar
Yes! i've already recoded dashboard!!!EWS3/Dashboard are OK!!!I think that problem is in the flash of 29F!!!because i try with 3 differents file inside the DME so car cranck with one of the 3 files!!!The problem is why car still can't start??? problem of VIN???checksum???
Thanks!!!
Do you have original file with correct EWS?
Do you have INPA? You can check EWS ISN with it.... >> Engine> F3>....
IF EWS is not empty/virgin, align can't done.
How about your car key, central locking working?
You have choice go to bmw service or use progman to recoding/update DME/EWS and dash...? If you don't get new original ecu file, recoding/programming make new one.
Tricks to resolve problem(found it)....:
Failing key or failing EWS, or EWS alignment required, read the codes out of the EWS module, and you should get something like wrong key used.
By the way, much quicker diagnostics for stuff like this is just to put a old spark plug in one of the coils and check it against the body. (Do not get shocked)
If no spark, that will confirm (but not solely, could be crank/cam sensor) a EWS problem.
If it has spark, assume fuel related, you can simply confirm this by spraying some quickstart into the intake, and the car should at list start/splutter.
Hi!!! i already reprogram Dash, ews(i have too correct mileage to dash=it's ok),VIN is the same between dash, ECU and EWS!!!I don't know the Checksum!!!!!
thanks!!!
i need ews files
Hello!Ok! here!!!
