Results 1 to 7 of 7
    Dec 2009
    uj egyenesen
    Default passat 3c 2.0 pdti dpf off
    hello. Please help the DPF off solution.tanks .. ECUSAFE NOT VORK.
    Baddog84's Avatar
    Sep 2012
    Germany
    Quote Originally Posted by eeprom View Post
    your file dpf off
    pass pm
    WinOLS 5, FGtech, Piasini, Powergate M, Byteshooter, OptiCan Dual II, EVC BDM, VCDS, BeeProg+,Ktag, Kess V3, Autotuner, Bflash
    Fileservice
    no thanks no pass
    Apr 2013
    Test and report, pass in PM.
    Dec 2009
    uj egyenesen
    not work..... smoke white idling...
    Dec 2009
    uj egyenesen
    Quote Originally Posted by Baddog84 View Post
    your file dpf off
    pass pm
    not work. white smoke idling..
    Feb 2010
    Babos's Avatar
    Mar 2012
    Your problem is not in DPF but after cut dpf you get see white smoke! it is mean you have problem with injectors replace and all be good!
    And one more thing take off egr and clean him.
    Best regards.
