Tr a different Cables XML mate
Are you doing net id scan or bruteforce
Service and bows here but for Liverpool ..............Paul
Morning all,
I dug out my old Dbox 2 and flashed it with the ultraphat image I found on a site and added a cables.xml file I found for Manchester, did a search and got most channels but not all - eg sky sports 5 is missing.
Also the regions for BBC1 and ITV1 are wrong - it shows up as BBC1 yorkshire and says 'channel not available', similar things happens with iTV1.
I know I am very close, any tips on what I need to do to get all the otehr channels - do I need a different cables.xml file or do I need to change some settings on my box? Or is there a channel list I can load?
I live in Manchester in a virgin area.
PAUL
milko8286 (16th August, 2014)
ive tried with both net id and brutforce - whats the difference?
got it sorted - went into the engineers menu on my tivo box and found my freq id and symbol rate. added them in when doing a scan and hey presto got the missing channels and the right regions!
I thought dboxes where no good anymore after n3 wiped the channel's off them?????
A LITTLE THANX GOES A LONG WAY
Are we now saying we can use DBox2 again? When did this happen?
Some time since you were last on line mate. ...
PAUL
Any up to date cables.xml file about.
Have full ver Ross-Tech Vag Com.
just use the latest cables.xml from another working image
also will have to update scan.config
or channels wont scan ....................Paul
PAUL
Note:All information given is to be used for educational purposes only and should not be taken seriously.
Hi All,
long time since I looked into this...are we now saying these can be brought back to life with the right image..will have to look in the attic I think.
yes mate 2009 is a long time ago
PAUL
Hi all, Has anybody managed to get it working again, i am completely stuck, i cant even get 1 channel, i am using commando 12, any help would be really appreciated
