Page 49 of 65 FirstFirst ... 39444546474849505152535459 ... LastLast
Results 721 to 735 of 971
  1. #721
    nici's Avatar
    Apr 2017
    Poland
    I found it. Solution looks OK. CP 8.21 work but not tested on car.
  2. #722
    nici's Avatar
    Apr 2017
    Poland
    Anybody know, why my CP after select some function in cp, ( eg. edc16 vag ) disconnect from usb ? Sounds like cable unplug. I dont know why, cable OK, tested on 2 pcs CP.
  3. #723
    Jan 2010
    Trstenik - Thun
    For ECU VAG A1+ adapter must be connected
    Sent from my JSN-L21 using Tapatalk
  4. #724
    Mar 2017
    hallo does the clone china carprog 8.21 online will works 70% of original device,i need it only for airbag,thanks all for help,how much it cost the original device from where i can buy it
  5. #725
    Jan 2010
    Trstenik - Thun
    Quote Originally Posted by ali lbl View Post
    No China clone never can do 70% of original.
    Original from codecard only!
    If u looking for good clone only
    EU clone is good solutions.
  6. The Following User Says Thank You to mikroel For This Useful Post:
    ali lbl (23rd November, 2019)
  7. #726
    Mar 2017
    Hallo friend where I can buy it the EU clone carprog,do you know how much it cost,thank you very much
  8. #727
    Jan 2019
    you found ?
  9. #728
    kadidiag's Avatar
    Sep 2014
    hi all friends i need to rework my device so i dont have MM74HC128M in my area but i have MM74HC14M so i need electronics men advice me about if are compatible am not electronic specialist.
    please help me brrs i wont to damage my device.
  10. #729
    Jan 2016
    Jumping Around the globe
    Tried to get radio code from vw technisat by using my original carprog, it failed, I get "read error"
    If i read the eeprom under the eeprom menu 24c16, it reads fine and i get dump. but cannot get the code.
    any ideas?
  11. #730
    Apr 2019
    Hello Mates.
    Can do rework on clone CP V10.93 offline version?
  12. #731
    Dec 2013
    Hello
    Any one have lucky reading carpass in opel vetra C ?
    Which version you used for it ?
    Regards
    Enviado desde mi iPhone utilizando Tapatalk
  13. #732
    Jan 2010
    Trstenik - Thun
    Quote Originally Posted by nexusjose View Post
    Hello
    Regards
    Yes by eu clone
    https://youtu.be/Ez-rMlgPGtY
  14. The Following User Says Thank You to mikroel For This Useful Post:
    nexusjose (24th January, 2020)
  15. #733
    Jun 2010
    EU Romania
    Test some one if can in one clone carprog unit to writhe the one valid serial know from one original unit carprog and after to use it the clone unit like original with internet update ?
  16. #734
    Dec 2013
    Quote Originally Posted by mikroel View Post
    Yes by eu clone
    Thank you
    I can read car pass i change 4 , 74hc125. I do test and never fail but it is no correct, change and work very good
  17. #735
    Jan 2020
    First off...thanks to all who have posted in this thread.
    I've reflashed my clone carprog with both the v4.47 and v8.21 at the beginning of this thread but when I connect the mcu to my computer and launch the carprog software the device is not recognized. I do not have usb human interface listed in device manager either. I've tried with both the 12v external power connected and without. The corresponding lib file from this thread is in the same folder as carprog.exe
    When reflashing the mcu I did not remove the at88 chip since the latest tutorials I found said there was no need to remove it.
    If I erase the mcu and connect to the computer the computer recognizes that something is plugged in but cannot identify it.
    I've tried multiple usb cables and multiple computers all with the same result.
    Is this a sign that either the at88 chip is corrupt or erased or maybe the mcu is dead?
    Does anyone have any suggestions to try to bring this back to life or should I just buy another mcu and start over?
    Thanks.
