Hello,
Any solution to renew w177 dkg.
Gearbox 8 gears.
Klass A 200cdi w177 2018
Or anyone know solution using any other tool.
Will pay by Paypal.
With Tapatalk
Hi there
I bought the New VVDI FBS3 Smart keys. Programmed it to the car and done. Insert key into ignition and starts. Remote buttons work. Press the start button and dash says CANNOT FIND KEY.
So it seems there is something missing in programming or what to do to get keyless to work?
Is there a special procedure to follow?
I tried FBS3 firmware update and still the same. Car does not detect keyless key. Only work if insert in EIS.
Hello
Need Erase password for Ecu mercedes
the special key is: EF6534BF839850CD
thank you
2005 C230 w210
Read EIS with VVDI Prog adapter
Made key
Esl unlocks, EIS turns, Cluster lights up, radio works, windows roll down, car doesn't start, there is a click under the hood when attempting to start
Customer said work has been done it was recently crashed and then the key broke, wasn't exactly clear on the order of events
Any ideas?
Sent from my SM-N960U using Tapatalk
milehighlockdoc (18th August, 2020)
Hello
I neeed Erase password for Ecu mercedes
thank you
ficho
CarCity (19th August, 2020)
Xhorse Keyless go keys works with cars from 2009 and younger
yugo45 (26th September, 2020)
