Page 367 of 450 FirstFirst ... 267317357362363364365366367368369370371372377417 ... LastLast
Results 5,491 to 5,505 of 6745
  1. #5491
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by drugowaz View Post
    With nec?.......
    no.....with potatoes only
    many thanks to friend kevfield
  2. The Following User Says Thank You to daxxer For This Useful Post:
    AjDaBeast (20th January, 2019)
  3. #5492
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Im mistaken? Earluer motorola was possible too. Just by solder?
    Renault ECU tool / IO terminal / A.S.W
  4. #5493
    Apr 2016
    dk veteran.... motorola only in 2006 year
  5. #5494
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Noncence! If done 06-08
    There was motorola in diferent year
    Last i did was w164 2007
  6. #5495
    Apr 2016
    changed after all key lost or real manufacture year was 2006
  7. #5496
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Sit down expert. I told you ibe done all year 6 7 8 with motorola . Eu usa eua
  8. #5497
    Apr 2016
    and then your alarm clock start ringing
  9. #5498
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Jul 2009
    In my immobox...
    W164/251
    Motorola 2005-2006,
    NEC 2006-2009 (no AKL so far -untill now),
    NEC 2009+
    4C7570755F73616E64755F696D6D6F5F736F6C7574696F6E73
  10. The Following User Says Thank You to lupu_sandu For This Useful Post:
    rojhat (18th January, 2019)
  11. #5499
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by lupu_sandu View Post
    W164/245
    Motorola 2005-2006,
    NEC 2009+
    245 are old Bclass
  12. #5500
    habbyb's Avatar
    Jun 2010
    Romania
    Hello , any update is OK , we look forward .
  13. #5501
    server work?
  14. #5502
    anyone confirm?
  15. #5503
    Jul 2018
    CHINA
    server back to work now ,
  16. The Following 2 Users Say Thank You to PerryZhang For This Useful Post:
    daxxer (21st January, 2019), milehighlockdoc (21st January, 2019)
  17. #5504
    Default VVDI MB TOOL IR READER CABLE BROKEN
    hi
    can i have the pinout for the ir reader, as my cable is snapped at connector end.
    dj
  18. #5505
    Mar 2010
    Timisoara
    when it read the data was at least the 12->15 retry
    i have 5 Elv and have the same behavior
    cable DB25 to OBD replaced with VVDI2 -> same
    W204 cable OBD to ELV to EIS connections are soldered and checked because the crimping job was
    what next
