Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: Ford F450 DPF
    eprst's Avatar
    Jul 2011
    Russia
    Default Ford F450 DPF
    Hello
    Please help disabled DPF Ford 450 SID902
    Regards
    Dec 2013
    Quote Originally Posted by eprst View Post
    Hello
    Regards
    Here dpf off mate
  3. The Following User Says Thank You to gitko For This Useful Post:
    eprst (14th December, 2015)
    eprst's Avatar
    Jul 2011
    Russia
    thanks, I will try and write the result
    eprst's Avatar
    Jul 2011
    Russia
    cars have driven 150 km and began regeneration of DPF and light error DPF on dashboard
  6. #5
    Dec 2013
    Hi did you reset dpf before and if you do,does you see the soot or ash how much is now and after?
    What dtc you have?
    Pass is the same
  7. #6
    eprst's Avatar
    Jul 2011
    Russia
    Tomorrow see diagnostic errors codes
    reset DPF done before
  8. #7
    eprst's Avatar
    Jul 2011
    Russia
    Today I did reset again and rolled through,
    counter km DPF growing
    Look Foto
  9. #8
    Dec 2013
    pass is the same
  10. #9
    eprst's Avatar
    Jul 2011
    Russia
    I will try and report
  11. #10
    eprst's Avatar
    Jul 2011
    Russia
    Hello! I am not sure that the soft, i have attached in the first post, is original. IDS Ford suggests me to update the soft, Look at the attachments. I have attached new soft. So, could you,please, do DPF off.
    Thank you in advance!
    Regards
  12. #11
    Dec 2013
    here is your dpf off on new file
    Pass is the same
    DPF/FAP off, AdBlue off, EGR off, Throttle valve off, Flaps off, DTCs off, Lambda off,
  13. The Following User Says Thank You to gitko For This Useful Post:
    eprst (23rd December, 2015)
  14. #12
    eprst's Avatar
    Jul 2011
    Russia
    cars have driven 150 km and began regeneration DPF and light on dashboard - look foto
  15. #13
    eprst's Avatar
    Jul 2011
    Russia
    anybody can help me?
  16. #14
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    SID902 it's one from rare ecu like newest DCU.
    Solution is not to easy, but like always - possible
    All brand FileService - Custom - remapping company
    POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
    | Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
  17. #15
    repairmymodule's Avatar
    Aug 2014
    USA, Earth, Milky Way Galaxy, Universe, Unknown
    How to read this ECU? Supported in Galletto BDM?
    Ive been thinking about buying an H&S one-time use tuner that comes with multiple maps. They program obd and then pull ecu and read file from bdm to use solution on other trucks.
    https://www.rpmoutlet.com/h-and-s-ra...dpf-delete.htm
    Im a virgin at ECU programming...im sure you can tell
