Results 1 to 12 of 12
    Aug 2013
    uk
    Default XPROG clone 5.5.5 flash atmega64 - ISP USBASP - HELP NEEDED
    Im need a little help guys
    i have to reflash my xprog clone 5.5.5
    i have a USB ISP USBASP Programmer AVR which is from ebay
    software im using extreme burner.
    im using files form http://www.digital-kaos.co.uk/forums...ht=xprog+5.5.5
    post 18
    vanos batam
    when im loading the .bin files i get error in software.
    im needing to select .hex files to load in to software to programe the atmega64
    either i need to have hex files atmega flash and eeprom or im doing someting wrong?
    ive looked at files for xprog 5.0 posted on here and they are in .hex format and load correctly into extreme burner..
    anyone have a different way to do with the files i have and the tool i have... maybe a different software
    any info would be great.
    ive searched and searched
    please could someone help.
  2. The Following User Says Thank You to thayer201 For This Useful Post:
    sshiref11 (9th October, 2022)
  3. #2
    Aug 2013
    uk
    anyone ???? help??
    Feb 2015
    Xprog 5.55 hex
    xprog.rar
  5. The Following User Says Thank You to skizo89 For This Useful Post:
    madbg (25th March, 2021)
  6. #4
    Dec 2013
    Hi man,
    here atmega files work ok 5.55 ver. Remember erase flash mem, erase eeprom mem, set fusebit, program flash mem, program eeprom mem.
    if need soft, i can upload.
    regards
    pass PM
  7. The Following 5 Users Say Thank You to mrtobby For This Useful Post:
    eduardo131 (3rd February, 2017), gbratk (23rd August, 2016), houdiag (31st October, 2016), just4upal (2nd November, 2016), kadi0209 (29th November, 2016)
  8. #5
    Sep 2016
    motpass please
  9. #6
    electronistul21's Avatar
    Nov 2011
    galati,romania
    i dont can understand for what raison use USBASP.can make this work very easy with UPA,easy and safe.
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
  10. #7
    Dec 2013
    mates... i goto ver 5.51... 5.5.5 is not good, very unstable...
  11. #8
    Nov 2012
    5.5.5 runs fine releasesd on mmh originally. Your not setting you fuse bytes right??? It only likes to run on xp.
    He has 5.7.6 but not public. They would know what unit he has. Thats why ony the cracked asians are released. You can make a simple programmer that uses your printer port on a old pc (forget real name) with some 100 ohm resistors????
  12. #9
    ZINE DDINE's Avatar
    Dec 2016
    Xprog box 5.5.5 Flash + eprom
    hello
    xprog 5.55
    *Atmega64 41
    Config.v5.5.5.bin
    EEPROM 5.5.5.bin
    Flash 5.5.5.binaounzine@yahoo.fr
    EEPROM 5.5.5.hex
    Flash 5.5.5.hex
    These users thanked
  13. #10
    Oct 2016
    MAROC
    motpass please
  14. #11
    peko's Avatar
    Jan 2010
    hi friends
    i write flash and eeprom after erase both them but without fusebit
    i confirm good write fine reading it after write and comparate data, all is ok
    you think xprog will work fine or i must made again using fusebit ?
  15. #12
    Mar 2021
    motpass please
    thanks!
