Can I ask for updates for my x431 here? =X if can't very sorry, I'm new.... the above updates by sogaro is oct 2010
for all x431 right?
I browse the thread backward and only saw this link shared, so I think this is the only version of update being shared?
Correct me if I'm wrong.
ET240
(Peace)
do u have the 2010 updates?
hmmm no reply guess everyone is bz ^^
Mates don't you read the rules?
It is prohibited to post or share softwears here in DK.
If you do this you'll be banned.
So if you need cracked sw for x431 why don't you ask Mr. dijo in PM?
It is easy.
Good luck
hello has anyone the new soft to crack x341 update files? , pls if you send to me pm
Thanks to he guys who take the time to help a fellow techie.
I'm not really a opel guy, would anyone know what could be wrong with a corsa B not starting.
Diagnosis in ecu - wrong imobilizer code
Diagnosis in imobilizer - no fault stored
I erased the key, recoded it with x431, but to no avail.
It start briefly, then dies, (the spark stops)
Sounds like imobilizer, but how do I fix it?
Any expert out there
Hi All, Fianally got my diagun, but its missing some car makes to diagnose....
If some one has software for SMART , LEXUS, ALFA ROMEO, LANCHIA in english or russian weould be very nice of you if you could share the cracked version.
Yeah its my first time on the forum too. Im hoping I can use it to score some free warez or something useful. I heard tht this site is legit.
Can someone please clarify if the 2010 cracked software will work on a Launch GX3 with a built in CAN? I read the "Readme" file that the cracked software works only on "pre-Master" X431 version. However, I also read in the threads that someone with a GX3 says it worked on his machine.
Thanks for the reply. I went thru the threads and there were some notes about changes to be made if the X431 is the "tool" or "inifinite" version. Some change to "identity" code. Then for the 2009 cracked software, someone commented about it not working for vehicles which require CAN. It was recommended to run the CAN Upgrade in the crack software. The GX3 and Master have CAN built in the box. So I assume this CAN Upgrade does not apply. I could be mis-understanding some of the posts. Am trying to figure this out because the old X431 and the GX3/Master version have a difference in the CAN. Old X431 has external CAN adapter. New GX3/Master has CAN built in the box and uses a simple 16e connector.
