well if you read posts you will find the answer, btw ur guy you spoke to is wrong.
Hi all
Been searching the forum.
I'm confused.
My box has been out of use now for about 6 months.
I switched it off while I redecorate the new house.
If not moved Area. I've a live vm line. Just recently set up by them.
Did the usual set up like I have for yrs.
No channels.!!!!😱😱
Spoke to a guy he tells me that kryptview is no more and my box will never work again.
Is this true?
Secondly if I can get it back to life. How do I do it.
I've done no updates, whatever.
Thanks.
750,780 and 850 are working but not with kv .those days are well gone.
usb flash with latest 850 then you need to add the special thing we cant talk about.
Special gift aid!!!
Can you send a link for the update.
there is an outside link posted in the kv threads by mods/admin as it breaks the rules if in downloads.
plenty of digging to find this.
http://www.digital-kaos.co.uk/forums...=1#post2775644
possibly more online updates after that so would need checking.
Thank you for link.
As I have the 850. Is it just the case of downloading the file on to USB stick (format fat 32) then update on to box. Or do I have use the old null modem route.
850 uses usb as like in the 850 tuts setup.
Hi all
Ok. I downloaded the file. Upload onto the box. Box rebooted. How do I know it's worked?
No still the same colour scheme etc.
I've downloaded the file I was pointed to.
I must admit the file did say 2012 which made me suspicious. If this is the wrong file can someone point me in the right direction. Thanks
Code:https://app.box.com/s/2od36dkyc4zwp1q14dk7i5uugvk7j00u
