Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
  1. #16
    Jul 2009
    azepako
    I have a very similar radio, PCB looks just about the same can you help please?
    Renault 281151185R
  2. #17
    ahmetusta61's Avatar
    Jan 2012
    E.U
    Quote Originally Posted by azepako View Post
    hello
    are u find solution for this device ???
    i have solution if u dont solved
    what is your solution
    i have martech box3
    <<<<----- THANKS BUTTON
  3. #18
    Dec 2016
    UK - South East
    I see that the radio isn't mounted to a car. It cannot work without being mounted to a car because it has CAN-H and CAN-L pins.
  4. #19
    Jan 2012
    E.U
    Quote Originally Posted by ovidiumarin View Post
    the same problem in the car continues
    i have martech box3
  5. #20
    Dec 2016
    UK - South East
    I read on other thread that a guy pressed the setup and return buttons and the message displayed on the screen changed to "seed: ......" (some numbers). Maybe this can help, maybe someone know how to find the key using that seed number.
  6. #21
    Jan 2012
    E.U
    where did you find that information ?
    i have martech box3
  7. #22
    Jan 2012
    E.U
    please help me
    i have martech box3
  8. #23
    epicsabi's Avatar
    Sep 2009
    Budapest
    hello
    what is your solution for this problem?
    I have same problem and I can’t find the solution! :-(
  9. #24
    Jan 2012
    E.U
    i have martech box3
  10. #25
    epicsabi's Avatar
    Sep 2009
    Budapest
    The original radio is stolen and the connectors are cut from harnes. The owner of the car bring me a radio and connectors from junkyard.
    My opinion is the problem the VIN in the radio is not same with the car’s VIN.
    I dont know how I can change the VIN in the radio...
    I have tried with original Abritus and I can’t change the VIN in the radio.
    If I help you don't forget press the THANKS and REPUTATION buttons
  11. #26
    Meat-Head's Avatar
    Quote Originally Posted by epicsabi View Post
    1) Tweet Abritus and ask them if its a genuine item
    2) can you change VIN IN OTHER modules to match junkyard vin
    3) call dealer, ask the question, can it be done and how much!
  12. #27
    epicsabi's Avatar
    Sep 2009
    Budapest
    Quote Originally Posted by Meat-Head View Post
    I can change the VIN all modules in this car by OBD...
    Only three modules failed.
    -Engine ECU
    -Steering
    -Radio
  13. #28
    Jun 2010
    EU Romania
    I have the same problem with this unit Visteon, from Duster 2019
    Part code: 281158515R
    Part Name: R013-X07
    Any solution ?
    Thanks and best regards.
  14. The Following User Says Thank You to Seby_TM For This Useful Post:
    Meat-Head (20th February, 2024)
  15. #29
    Jun 2010
    EU Romania
    I made diagnositc in car and I see the radio not have the same VIN like car and for this reason show Locked in display !
    I try to change VIN in radio by OBD with AVDI online and not let me to do it.
    I find in bottom side of unit also some pads TX, RX and XCLK I think this can be a solution for change or update VIN in MCU, know some one solution to chenge VIN in this unit radio ?
    Thanks.
  16. The Following User Says Thank You to Seby_TM For This Useful Post:
    Meat-Head (3rd March, 2024)
