Page 107 of 136 FirstFirst ... 75797102103104105106107108109110111112117 ... LastLast
Results 1,591 to 1,605 of 2027
  1. #1591
    hardou's Avatar
    Apr 2018
    Default edc17C01
    quelqu'un peut-il m'aider à désactiver ADBLUE dpf sur la mercedes edc17C01 0281016102 s'il vous plaît?
  2. #1592
    Mar 2019
    Default Any "OFF" file (DPF, EGR, SCR, FLAPS, DTC) for FREE!
    Hi.Can I get EGR,DPF and Adblue off on this EDc17CP44 Audi Q7
    EDC17CP44ORIG.zip
  3. #1593
    Nov 2021
    Default ROBINFULL
    PLZ I NEED EGR OFF FOR KIA CERATO RDC15C7 THANK YOU
  4. #1594
    DK Veteran andrym3's Avatar
    Nov 2009
    Default edc17cp14
    Please dpf off hyundai tucsson EDC17cp14
  5. #1595
    Feb 2021
    UK
    Default HOWO EDC17CV44
    Can you help with SCR OFF on this HOWO Truck ?
  6. #1596
    Yhoni's Avatar
    Jun 2014
    Somewhere in time...
    Quote Originally Posted by OliverC View Post
    EDC17CP44ORIG.zip
    Hello friend, are you sure of the reference of the ecu, edc17cp44, please ?
    If my post has helped you, do not forget to click on the "THANKS" and "REPUTATION" button !!!
    I do not answer in private questions that can be solved in public.
  7. The Following User Says Thank You to Yhoni For This Useful Post:
    mapino (7th January, 2022)
  8. #1597
    Yhoni's Avatar
    Jun 2014
    Quote Originally Posted by andrym3 View Post
    Hello friend, here is your file.
    Click "THANKS" AND "REPUTATION" button and then i will send your password.
    Greetings.
  9. The Following 2 Users Say Thank You to Yhoni For This Useful Post:
    andrym3 (26th November, 2021), mapino (7th January, 2022)
  10. #1598
    Oct 2011
    Croatia
    Default renault ddcr egr off
    please i need help with renault ddcr 8200331477 8200374171 .
    i need egr off.
  11. #1599
    Sep 2009
    hello can you help with DPF off of bull EDC17c69 tc1793?
  12. #1600
    Aug 2020
    Birmingham,England
    Quote Originally Posted by cuheitoariel View Post
    here you go mate
    DPF With Associated DTC's Deleted
    Checksum corrected ready to write
    IF I HELPED YOU DON'T FORGET TO HIT THANKS AND REP
  13. The Following User Says Thank You to geedot187 For This Useful Post:
    cuheitoariel (30th November, 2021)
  14. #1601
    tato10's Avatar
    Mar 2010
    LA PLATA ARGENTINA
    Hi mates, could somebody help me to make EGR off from mercedes sprinter 411 delphi CRD2?
    i will give tanks and reputation who can help me.
    regards
  15. #1602
    Feb 2020
    Default JCB Ecomax EGR OFF
    Hello
    I need help with EGR in delphi DCM3.3+. Somebody can completly delete P0400-00 DTC?
    I want to disconnect actuator and completly remove EGR related parts.
  16. #1603
    Dec 2021
    I want DTC P0420 and p0430 off.
  17. #1604
    Jan 2020
    HI THERE PLEASE HELP WITH EGR/DPF OFF PLEASE
    RANGER 2.2 SID208 ECU
  18. #1605
    Sep 2021
    Comores
    Default DPF EGR SCR RENAULT TRAFIC 3 1600 DCI EDC17C84 UDM
    Hi mate,
    I need help removing the fap, egr and adblue from a Renault Trafic 3 EDC17C84 if possible.
    I read in obd with pcmflash and I sent the file to a chiptuner and paid for it and I wrote this file and now it smokes white when we stop the vehicle. I tried by unplugging the fap temperature probe and the dff pressure sensor. It's the same. I tried by disconnecting the adblue pump and the adblue ecu and it's the same. It still smokes white when stop the vehicul.
    I really have help please.
    For information, I cannot access the UDM ecu from the diag and I want disable the scr with renolink but I don't see where is it.
    My version Renolink is V1.90
    Have you a solution, please?
