Did you unlock ecu?
Wysłane z iPhone za pomocą Tapatalk
trying to read PCR2.1 by VCP (VAG CAN PRO genuine) in boot, but not working. Actually I need only MCU ID.
Getting communication on bench, can read flash file.
In ECU flasher menu selecting PCR2.1 EEP.
Switching of power supply, and connecting wires and resistors by chematics (strange that one resistor marked in red and looks like "+" sign there..hhhmm)
trying to read by "Boot MCU".
When trying to read always getting answer NoBootACKFrm, the same answer when reading with switched off power supply or disconnected OBD plug.
ECU on bench using 0.4A and with resistors connected 0.2A (looks like it should be in boot mode), when trying to read "BootMCU" can sea blinking for split second CAN-H and CAN-L LED's, looks like there was attempt to read, but amperage staying the same 0.2A.
p.s. on Win XP diagnostics works, but not recognising ECU on bench. Win7 x64 reads ECU flash on bench.
Any ideas?
Kind regards
Did you unlock ecu?
Chiptuning - Diesel / Petrol / Stage1,2,3 / HIGH Petrol Tuning
DSG TUNING
DPF / EGR / TVA / SAI / Lambda
Crackle map ( Launch Control + No lift Shift + Antilag )
File Service
PCMFLASH / BFLASH / AMT BST / AMT MPPS / TGFLASH / BITBOX / EDCSUITEPRO - Genuine USER
yes, unlocked before
why you dont read obd
"Actually I need only MCU ID"
not too many tools can provide this data, for flashing I have other tools.
can't ID ECU and even not able to reflash without ID.
ECU is bricked, end of story.
flashing frf and get up
FILE SERVICE
vcp cant connect to it, vas cant connect on table with it.
use smok uhds or avdi, write full flash and car start....
FILE SERVICE
kvadratas (12th January, 2018)
cmd has a recovery function
Everything ok. But You should do it by OBD2.
