Page 1 of 2 12 LastLast
Results 1 to 15 of 30
Thread: DCM 3.5 problem
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Default DCM 3.5 problem
    Hello, yesterday i managed to kill dcm 3.5 via obd. genuine cmd failed... CMD did vread, i writed file with dpf off mod, and after that no connection with ecu. Cmd says " no data from ecu. Kess says " cant identify chasis " or smth.. I tried to write ori (vread) file Usprog, but no luck. THen i readed ecu. I saw that cmd missed all MAPs zone. Now i have galleto, i can read write with jtag. Ori vread file is 3.072Mb size, galleto read 3.073Mb. I can write cmd readed file with galleto, because i get error. I tried a lot of solutions, but none of them cant bring my ecu back to life. I attach ori cmd read, then usprog read after cmd crashed, and then file that i readed with galleto. Maybe someone had this issue in past. Or someone have ori file readed with jtag pinout.
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    Cmd and some others tool do this problem,galletto in jtag mode is the best for this type of ecu
    Sent from my SM-N910P using Tapatalk
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
  3. The Following User Says Thank You to AVDigitale For This Useful Post:
    Ignasvw (7th February, 2018)
    DR Race's Avatar
    Dec 2017
    Dracula's country
    I have done with kess dcm3.5 only OBD, and till now no Problem , i mean Ford delphi dcm 3.5 , normal file from kess has 3.5 mb , if it help I can send you ori file one read with kess , and I think I have mpps also, 140 and 163 hp , if you need I will post file !
    Trimis de pe al meu SM-G930F folosind Tapatalk
    Inquizit0r's Avatar
    Aug 2013
    Ukraine
    KESS has no problem with Read/Write DCM3.5 Ford via OBD. Even on 12.3-12.5V.
  6. #5
    DR Race's Avatar
    Dec 2017
    Dracula's country
    Quote Originally Posted by Inquizit0r View Post
    Yes I do Ford dcm 3.5 always with kess, no problem till now ! Always 12,5 -13V !
  7. #6
    johak's Avatar
    Apr 2010
    the problem is probably the wrong checksum
    if you want to try this with galleto
  8. The Following User Says Thank You to johak For This Useful Post:
  9. #7
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    guys, thanks for reply, but i know that almost all chinese can do it without problem. But its genuine cmd, i didnt expected that it will destroy that file. I better need bdm read of this ecu
  10. #8
    DR Race's Avatar
    Dec 2017
    Dracula's country
    Somtimes shit happend , i hope you can bring ecu back to life, recovery from CMD ??? You have to report this to cmd , they can help you , call support cmd!
  11. #9
    Jun 2013
    EU
    Quote Originally Posted by Ignasvw View Post
    Try flashing this one with galletto
    Regards
  12. The Following User Says Thank You to morgano For This Useful Post:
  13. #10
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Write as full or only micro?
  14. #11
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Quote Originally Posted by morgano View Post
    Regards
    Already tried this solution
  15. #12
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Quote Originally Posted by johak View Post
    i tried this solution too....
  16. #13
    Jun 2013
    EU
    Was worth trying
  17. #14
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    i tried maybe 10 solutions...
  18. #15
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Is problem solved? Maybe try with Abrites to flash ori?
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
