Results 1 to 12 of 12
    Jul 2016
    Default AIRBAG AUDI A1 BOSCH 0285010535
    Hi mate, I need help to clean files crash airbag audi a1 8X0959655, BOSCH 0285010535, attached files crash
    s qubiak's Avatar
    Jun 2017
    Polska
    Made in Poland
  3. The Following User Says Thank You to s qubiak For This Useful Post:
    davidtrus (9th May, 2018)
    Jul 2016
    does not work, accuses internal error
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Your cleared file.
    You use srs units files at your own risk. I am not responsible for any damages. Don't ask about passes, one file=one pass.
    If I helped, please, use magic buttons reputation+thanks.
    Best regards.
    Dragon
  6. The Following User Says Thank You to dragon100 For This Useful Post:
  7. #5
    Jul 2016
    thanks dragon 100 solved
  8. The Following User Says Thank You to davidtrus For This Useful Post:
    dragon100 (9th May, 2018)
  9. #6
    Mar 2016
    I am also asking you to remove the collision data from the file, or password to the dump from Dragon100.
    Best Regards
    Maciej
  10. #7
    matik185's Avatar
    Jun 2018
    Europe - PL
    Quote Originally Posted by automaciek25 View Post
    Best Regards
    Maciej
    It will be faster if you use VCDS or other diagnostic software - it takes 1 minute to delete crash...
    Why everybody with VAG SRS Ecu like to complicate everything ..
  11. #8
    Mar 2016
    Quote Originally Posted by matik185 View Post
    I just do not have a car, the customer gave the module to do and I do not have to check. I thought it was just a diagnosis ...
  12. #9
    dragon100's Avatar
    Jan 2012
    If you clear only vcds, crash is away but in measuring blocks will be crash ...
    Best regards.
    Dragon
  13. #10
    matik185's Avatar
    Jun 2018
    Europe - PL
    Quote Originally Posted by dragon100 View Post
    I know , the count will be 1 - but its safe, and airbags for sure will work..
    When he will try to sell car - he should tell buyer about airbags ignition
  14. #11
    Feb 2020
    What is the password?
  15. #12
    Feb 2020
    [QUOTE = dragon100; 3277786] Seu arquivo apagado. [/ QUOTE]
    What is the password? Thanks
