Results 1 to 6 of 6
    Jan 2014
    Default Focus 1.6 TDCI 0 281 015 242 8M51-12A650-XC replacements other numbers?
    hello, my ecu Focus 1.6 TDCI 0 281 015 242 8M51-12A650-XC is dead. I want to make clone. Should I buy ECU with same number or are there any replacements numbers?
    Dunker's Avatar
    Yorkshire
    If there's a PCB/hardware number on the sticker then if you get one the same you can clone the flash/eeprom from yours assuming you can read them (even if your ECU is dead this is sometimes possible). Or maybe get dumps of your ECU from DK or wherever and program new ECU up and code keys in. Only way to find out is to try. Take back off your ECU and search for images of ECUs and see what part numbers they have. Ive cloned ECUs with different numbers but you need the circuit boards to be identical in any case. You can also reflash with VCM but you will need to fool IDS into thinking its a brand new ECU. Just dont turn ignition on when IDS tells you to then enter your original ECUs 8M51 number when asked.
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
    rafal's Avatar
    Jul 2010
    UK - PL
    ori PCM 8M51-12A650-XC and replacement :
    5U71-12A650-AB
    3M51-12A650-MJ
    3M51-12A650-MK
    3M5A-12A650-JH
    4M51-12A650-KJ
    4M51-12A650-NG
    4M51-12A650-NH
    4M51-12A650-NI
    5M51-12A650-LD
    6M51-12A650-MD
    6S61-12A650-VA
    6S61-12A650-VB
    6S61-12A650-VC
    6S61-12A650-VD
    7M51-12A650-TD
    8M51-12A650-LC
    8M51-12A650-LD
    8M51-12A650-LE
    8M51-12A650-LF
    8M51-12A650-LG
    8M51-12A650-MC
    8M51-12A650-MD
    8M51-12A650-TB
    8M51-12A650-TC
    8M51-12A650-UC
    9M51-12A650-DB
    need help
    now my goal is to buy xp-005
    who will help?
  4. The Following User Says Thank You to rafal For This Useful Post:
    Dunker (24th May, 2018)
    May 2017
    8m51-12650-xc
    please help repair dump PCM.
    DTC P1603
    Eprom problems.
  6. #5
    Feb 2016
    Craiova,Romania
    hello!how did you solve?i have the same error and I can not get rid of it.... please answer me
  7. #6
    kiszka's Avatar
    Aug 2009
    Quote Originally Posted by petre18c View Post
    share eeprom ecu
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
