Page 1 of 2 12 LastLast
Results 1 to 15 of 19
    Aug 2012
    Default FIAT PUNTO 1.3 MJD8F3 DPF OFF
    Hi Mates. I need dpf off for MY 2014 1.3JTD 00 PS. ECU MJD8F3
    i try more than 2 soultion work little then get off
    trusted soultion please
    macako6's Avatar
    Mar 2015
    file can not be downloaded
  3. The Following User Says Thank You to macako6 For This Useful Post:
    NORSHAN (8th July, 2018)
    Aug 2012
    uploaded again
    macako6's Avatar
    Mar 2015
    OK , now ok
  6. The Following User Says Thank You to macako6 For This Useful Post:
  7. #5
    carbon7319's Avatar
    Aug 2011
    Macedonia
    No problem with download.
  8. The Following User Says Thank You to carbon7319 For This Useful Post:
  9. #6
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    reset dpf soot and oil service pass in PM!
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
  10. The Following User Says Thank You to AVDigitale For This Useful Post:
  11. #7
    macako6's Avatar
    Mar 2015
    Here's your DPF OFF Punto
    first you have to reset DPF 0%
  12. The Following User Says Thank You to macako6 For This Useful Post:
  13. #8
    macako6's Avatar
    Mar 2015
    Always do the procedure dpf replacement and reset parameters with ori file. then load this
  14. The Following User Says Thank You to macako6 For This Useful Post:
  15. #9
    Aug 2012
    so thanks friend all soultion didnt work rpm 3000 only dtc found p1564 all dpf sensor disconncted
  16. #10
    pike's Avatar
    Sep 2013
    Hi, your SW number refers to the Fiat Doblo, did you confuse anything?
  17. The Following User Says Thank You to pike For This Useful Post:
    NORSHAN (9th July, 2018)
  18. #11
    macako6's Avatar
    Mar 2015
    Quote Originally Posted by NORSHAN View Post
    I have tried this SW and worked well, did not report any error (all sensors stay connected)
  19. The Following User Says Thank You to macako6 For This Useful Post:
    NORSHAN (10th July, 2018)
  20. #12
    Aug 2012
    any body has trustrd soultion
    dtc p1564
    p2002
    p1302
    p2452
    p1206
    and rpm cant excced over 4000 rpm
  21. #13
    macako6's Avatar
    Mar 2015
    Try this file
    same pass
  22. The Following User Says Thank You to macako6 For This Useful Post:
  23. #14
    Aug 2012
    so thankh freinds all soultion above didnt work car in limpe home mode rpm 3000
    any trusted and tested soultion please
  24. #15
    TuningInside83's Avatar
    Dec 2016
    Italy
    Write this
    Pass PM
  25. The Following User Says Thank You to TuningInside83 For This Useful Post:
    NORSHAN (11th July, 2018)
