Nabilosat Enigma1 DarkStar II - DM500
What is new in this DarkStar II DM500 ?
Updated CVS: 30 August 2008
The image has been completely recoded based on the latest CVSUpdated Skin by porto
New DarkStar II skin customized by portoEnigma 1 Integrated 8 Days Sky IT EPG
Download 8 days Sky IT EPG, and have it integrated to Enigma1EPG Event Search
Select a single channel EPG, press 0, enter a keyword and search for your preferred eventsEPG Channels Selection
Customize the list of EPG channels to download. We reccomend to restart Enigma upon completing the selectionEPG Channels Update List
Update the EPG channels list when there are changesStandby after reboot
Your DM will automatically standby after an accidental reboot, such as after a powercutScheduled Reboot
Schedule an automatic daily reboot
Main Function Keys
Button 1xOK = Light Info OSD
Button 2xOK = Extra Info OSD
Button Blue = Nabilo Blue Panel
Button 2xBlue = Nabilo Extra Settings
Button Yellow = Nabilo Yellow Panel - Plugins List
Button 2xYellow = Nabilo Yellow Panel - Addons Manager
Button Red = Current Channel EPG
Button 2xRed = Select Channel EPG or MultiEPG
Features
Addons
Dedicated Addons Server
Download and install additional packages from Nabilosat server
Infobar/OSD
Enigma1 Analogic Clock
Channel Orbital Position
Advanced Tuner Info: Sr Freq Pol Fec
Signal SNR, AGC, BER
Infobar Picons
Advanced EMU information
Nabilo Panels features
1) Blue Panel
Extra Settings
Inadyn
Nabilo EPG Settings
Nabilo OSD Preferences
Nabilo Scheduler
Mount PointsSystem Info
Dreambox
Mount Points Info
Process Info
Memory Info
Enigma Setup
BitstreamSave
Select/Start/Restart EMU
2) Yellow Panel
Forums
Shoutbox
Addons
Scripts
Addons Download Manager
Manual Install Panel
Addons Uninstall Panel
Images Uninstall Panel
Nabilosat Statistics
Many thanks to the Beta Testers Team
Black33, ^^Corrado^^, ^^Maximo II^^, greg, Matrix10, Porto, ^)0(^Nabilo^)0(^, Army, Piefav, Franzjuve, Willow, fbrassin, Neri73, frimmino, astemio, DeepDiver, lorenzo64, robyhummy.
Credits
Sky IT Epg fully integrated to Enigma 1 by the great MaxZ4.
Many Thanks to lukkino (VDR-Italia) for opentv source code.
P.S. Soon another one version of image will be released for VPN users
Updated CVS
Enigma1 Integrated Sky IT EPG
EPG Channels Select & Update
8 DAYS Sky IT EPG
EPG Event Search: press 0 on single channel EPG
Enter an event keyword
Press OK or the Green button
Keywords will be saved to speed up next search
Nabilo Scheduler
http://www.digital-kaos.co.uk/forums...-ii-dm500-320/
::::>>Nabilosat<<::::
BlackHole project
has anyone tried this image with the Dreambox 500 plus? Just to make sure it`s compatible before trying..
hi
i want to download the nabilo darkstar 2 for dm 500
is good?
is it good? Any comments from who've tried?
Looks good but had problems with Astra 28.2 did'nt do a full scan only found some channels also came up as Astra 28.4 small bug i think. I'll wait for an update good luck.
In satellite list delete all the satellite that you dont use and add astra 28 then try to do a search.
This is not an immage bug but cvs
BlackHole project
I put this on my DM600c.
First impression was , very nice image, i love the clock.
a couple of probs though i found.
on cable, in the info bar , you dont get the now and next programmes whats on.
also the back up facility dont work. I installed the Mr Dude plugin for this , but its not recognised as a Nabilo file, so wont Backup.
Also you will need your cables.xml as the one that came with the image i got on isnt for the UK.
I hope they work on these few points as it is a very nice image.
Hi mate
unfortunatly our images are all tested on "S" boxes i will report your problems hoping that someone as a cable box to sort those out.
thanks for your feedback
ciao
BlackHole project
i have tried this one ...
I am not pro about Dreamboxes ( at least now ) , but its really good one and its working faster on switching channels.
I have ot the same problem with 28.2 and 1.0W Thor, The reason for this is that there are two satellite .xml file one in the image and one in var/etc. In the image the satellite.xml has the 28.2E as 28.4E so it doesn't recognise the channels. On 1.0W the image has the satellite as 0.9 so the channels don't work as they are set for 1.W. So unless Captain Picard redoes his channels to 28.4E and 0.9 we are a little stuffed. The really weird part is I have the DM500S configured with Nabilo v8 and the Captains settings and it works perfectly.I tried the same on Dm600 but no luck.
Hello, here same problem...do we know when to expect a corrected image?
also, how should I flash this image? I mean, should I erase the current one in my DM500s and flash this one after? or over the current one?
Will the port 12000 be still opened after the flash? or is there a trick?
vblanche
You could try adding the sat manually as it worked for me. Posted by digidude on another forum
AFTER downloading the captain channel list
press menu
setup
sat config
highlight 0.8W and press the red button to erase it
press the yellow button, a new box will appear at the bottom with a random satellite in it
press ok
scroll down to 1.0W
press ok
press green to save
press exit
go down to auto transponder scan
press ok
now in the list you should have 1.0W, highlight it and press ok
wait for a transponder lock
press green to scan
sorted
Hi, thanks for your reply.
I'm not in UK but the netherlands...I need to find the equivalent of 0.8W...
I think people here are using siruis 3/5E.
Also, is your method using usals or the GOTO feature?
vblanche
I am using usals where it goes automatically to the satellite.
