Hi all
I have just imported a honda Fit (JAZZ) the clocks are in KM I have purchased a UK clocks from a 2011 model. Mine is automatic the uk spec is i Shift hence a later clocks.
I have dumped the bin file successfully heres the part im stuck on is correcting the millage Tachosoft 2.3.1 doesn't have my year(Honda fit 2008) the 2007 model states:
Car type: Honda Fit - 93c76 - 2007 years
The mileage is stored in the next lines:
01A0: 62 00 9D FF 62 00 9D FF 62 00 9D FF 62 00 9D FF
01B0: 62 00 9D FF 62 00 9D FF 62 00 9D FF 62 00 9D FF
01C0: 62 00 9D FF 62 00 9D FF 62 00 9D FF 62 00 9D FF
01D0: 62 00 9D FF 62 00 9D FF 62 00 9D FF 62 00 9D FF
where the next bytes:
62 00 9D FF - is a mileage
which looks similar to my 2008 dump i have amended all the addresses with the corrected millage from the calculator but when the dash is fired up its all blank
I'm new to this and its the first time doing this please can someone advise me where im going wrong. I don't usually like asking for help so thank you in advance.
I would like my millage corrected to 42000 Miles current millage is 3597 miles
mugen889 (17th January, 2019)
thank you for your reply the dash did work when connected it was displaying 3596 miles.
try this and report
try this 42014ML.....
Mileage in his dump is 3597, and that is what he says it displays.
Your script is faulty. Not all dashes need to be converted to Km to calculate them.
I'll bet your file displays over 68,000 teerak2uk file is correct.
This also shows the importance of including the original reading when asking for help.
Please DO NOT PM me asking for help.
Post in the forum, that is what it is here for.
he asked 42xxx in ML not in KM so I gave him what he asked for.. you are right about 67xxx in km.. > ML 42.......
THANK YOU SO MUCH I LOVE YOU GUYS
what was i doing wrong so i dont have to trouble you in future
I will get this programmed tomorrow and update you guys
see pic for millage these are uk cluster
don't use my dump m8 there is 42... in ML that will show in dash 67...Km
no problem thank you for taking the time to look at this for me
im just curious to know how do we know where and how to change the file to correspond to millage am I missing something ?
it Appears Terrak2uk's Dump did not work the millage and trip A and Trip B were all blank.
I thought I had duff clocks so I put the original dump back on and it worked so clocks were not faulty but the dump.
Cllau dump worked but its not the millage I require and also the service indicator states -999999 too is it possible to get that removed?
can someone help me amend a dump with the correct millage
thank you again
Try this one,
