WVWZZZ13ZAV... is the VIN of this ECU... It seems that itīs 2010... 100% it has TPROT... chceck it...
Try to flash it with ODIS/ODIS-E with Ori SGO...
When I help you press Thanks and Reputation...
Hello,
I have read the maps of this ECU (EDC17CP14) with FG Tech 4 by the OBD.
When I was writing the new maps I got an error, So I dismantled the ECU and i tried to boot it but when it was at 3% the following error appeared: ERR FILE 014400 - OTP SECTOR NOT WRITABLE
I can read the current eeprom and internal flash, but i canīt write the internal flash.
i have tried to write with kess V2 (Boot mode) too but without result.
I havenīt got the original EEPROM file, i just have the int Flash original file and the EEPROM that i could read with Galleto after the error.
I need to write this ECU, right now It's just an ugly paperweight.
Thanks in advance!!
sparkecu (24th March, 2019)
hi!
try to write it with ktag by bdm
good luck
For this solution you need to write FRF file with ODIS E
i think he try in bootmode write partial file. .. Its your car given you killed?
My English is little bit bad, but day after day is better. Like my experiences https://www.youtube.com/channel/UCdT...bx2Pc7WI4pWUWA
My help not for free, press THANKS and REP, for make me HAPPY
im not using passwords, my work is for this forum and members free
OTP one time programing.
In ecu are are these location in mpc (for immo-no ecu swap--- but today its gone)
If you want to car start, put original read by obd back by obd.
in this ecu is Tprot (tuning protection)
Solved with ODIS, thank you for your help guys.
