Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    Member Itumeleng's Avatar
    Feb 2018
    South Africa< free State, Bloemfontein
    Default Mini cooper R56 dash mileage adjustment
    Hi Guys,
    I need help with mini R56 dash mileage adjustment. I installed a replacement cas3, changed VO and cluster showed high mileage which was in replacement CAS. How do I reduce mileage is cluster?
    Sent from my HUAWEI CAN-L12 using Tapatalk
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    read cas....then mileage to 0 km
    read dash...then put your mileage desired
  3. The Following 3 Users Say Thank You to jomberykaso For This Useful Post:
    brend (18th June, 2019), Itumeleng (18th June, 2019), Yhoni (19th April, 2021)
    brend's Avatar
    Oct 2015
    Same where
    Or load dash and cas eeprom for set new km.
    NB!!! Don't ask in PM old file password , Im not remember.
  5. The Following User Says Thank You to brend For This Useful Post:
  6. #4
    Feb 2018
    Okay, CAS I can read but dash which one? Top of steering or centre? And which eeprom is there?
  7. #5
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by Itumeleng View Post
  8. The Following 5 Users Say Thank You to brend For This Useful Post:
    brane0001 (7th May, 2020), Chupsy (29th December, 2020), Itumeleng (18th June, 2019), rtbdiagnostic (19th June, 2019), Yhoni (19th April, 2021)
  9. #6
    Feb 2018
    Thanks Brend, will get on it tomorrow and report back
  10. #7
    Feb 2018
    Got it right! Much appreciated guys.
  11. #8
    Jul 2019
    Germany
    Hi, only in CAS and dash are stored the mileage? In dash what eeprom is, can be read in-circuit? To write i need to replace the eeprom or i can use the same? Thanks
  12. #9
    Apr 2018
    EU
    Dash has a 35080 inside, you need a good programmer to do the job.
  13. The Following User Says Thank You to Diagcar1 For This Useful Post:
    christensen (13th July, 2019)
  14. #10
    Sep 2013
    M35080 Programmer is good for this kind of eeprom. (The red one programmer)
    For this job I always replace dash eeprom for a new one with mileage edited.
  15. The Following 3 Users Say Thank You to jomberykaso For This Useful Post:
    christensen (13th July, 2019), neksus (18th December, 2020), sagie1zn (30th July, 2019)
  16. #11
    Jul 2019
    Germany
    Thanks guys! I have UPA 1.2, TL866A, Carprog V9.31, FDVI, X-PROG-M V5.0
  17. #12
    Sep 2015
    DK
    Carprog can erase km on 35080 than you can write new km. If it is 35080vp you need better tool to erase.
  18. The Following User Says Thank You to baygrozdan For This Useful Post:
    christensen (15th July, 2019)
  19. #13
    Apr 2019
    NC
    HI WOULD UPA 1.5 WORK FOR MINI COOPER MILEAGE>? TO READ CAS AND DASH CLUSTER?
  20. #14
    levisdj's Avatar
    Apr 2010
    EcuLand
    Quote Originally Posted by donchester View Post
    Simple : NO!
  21. The Following 3 Users Say Thank You to levisdj For This Useful Post:
    brend (31st July, 2019), donchester (31st July, 2019), jomberykaso (30th July, 2019)
  22. #15
    Apr 2019
    NC
    ok thank you
