Results 1 to 5 of 5
    Aug 2015
    Default Galaxy 2012 key add
    Hi to all. The patient is the Galaxy MK3 from 2012
    I have to change BCMii. The old one was damaged during the ELMConfig configuration change. Read CCC configurations, save copies, but when trying to upload at around 80%, an error occurred and the instrument cluster went out.
    I installed a used module with the same number BG9T14A073BL
    I can't find a clear source for answering a few questions.
    Can Forscan with an extensive license program PATS?
    Can the original key that was in the car be re-coded?
    Do I need 1 or 2 programming keys.
    Where to purchase incode for query 1040 xxxxxx 000000.
    At the moment BCMi sees 0 saved keys.
    Will IDS (not original) be able to do more?
    Jul 2013
    yorkshire
    Forscan with extended license will program PATS. Original key can be re used. You need 2 keys. In the Forscan forum is a contact to get incode for free once regested.
    Aug 2015
    I was looking wherever I could but the available claculators are for old algo.
    after 05/2010 is new algo 1040... outcode
    Ashraf6119's Avatar
    Nov 2009
    UK
    Try this site............
    http://www.autokeyprog.com/login.php
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    Aug 2015
    They no calculate new pats code. only to 05/2010.pats.jpg
