Results 1 to 9 of 9
    Aug 2019
    Romania
    Default Opel Vectra B X16XEL Immo OFF
    Hello there,
    I got an Opel Vectra B witch is not starting.
    As i check i observed that the owner does not have the Transponder into the key.
    Is there any way to make immo off since the owner does not have the transponder anymore?
    Part Number: 16202319
    Aplha COde : NL
    Ecu TYpe: X16XEL
    Thanks!
    Nov 2013
    No immo off for such ecu
    Read tms ic in immo around ignition key
    Extract pin code and code new transponder id 40 via obd
    Or from dump via tango or tm100
  3. The Following User Says Thank You to samehlila For This Useful Post:
    BadeaCristian (8th December, 2019)
    Aug 2013
    Poland
    you can do immo off in this ECU. You have the pattern in the attachment. You must disconnect immobox. Dont forget click thanks and reputations.
  5. The Following 6 Users Say Thank You to kowal5 For This Useful Post:
    alexeybulatow (4th January, 2024), BadeaCristian (8th December, 2019), beepprog (2nd November, 2020), kork12345 (7th October, 2022), misho2318 (21st May, 2021), zaycew (8th March, 2021)
  6. #4
    Aug 2019
    Romania
    Quote Originally Posted by kowal5 View Post
    can't download it.
    can you upload it again?
  7. The Following User Says Thank You to BadeaCristian For This Useful Post:
  8. #5
    Aug 2019
    Romania
    Quote Originally Posted by samehlila View Post
    Do i need a new transponder id40 or i can program an used one?
  9. #6
    dantetimoc's Avatar
    Mar 2010
    you need a new id40 transponder or precode one pcf7935 to id40 with zedbull ...
    Autotuner- Kess - Ktag, genuine master tools.
  10. #7
    Apr 2016
    Russia
    i have same ecu anyone to help me immo off?
    Aplha COde : NL
    Ecu TYpe: X16XEL
  11. #8
    rafal's Avatar
    Jul 2010
    UK - PL
    Quote Originally Posted by car00ly View Post
    Aplha COde : NL
    Ecu TYpe: X16XEL
    Read again whole thread carefully.....then come back
    need help
    now my goal is to buy xp-005
    who will help?
  12. The Following 2 Users Say Thank You to rafal For This Useful Post:
    miroopel (15th October, 2021), volodin69 (17th October, 2021)
  13. #9
    Nov 2017
    Dobruja
    Quote Originally Posted by BadeaCristian View Post
    Carprog can read this hsfi-c code by obd. No need to read TMS.
  14. The Following 2 Users Say Thank You to volodin69 For This Useful Post:
    budata (15th October, 2021), miroopel (15th October, 2021)
