I have tried to write same file.... here on DK someone said that with same file galletto when writing it back to the ECU will make it virgin.....but it didnt.
Can someone make it virgin
Regards
ECU read with galletto....need virgin from this file.... ori ECU is missifiring, and not with a easy solder job.
ECU:
IAW 59F.M3 61600.376.07
HW 303 / 1812-0MZ
71736339 D032
X-Prog 5.60 / Upa-Usb 1.3 / CarProg 4.74 and 7.28 / MiniPro / Galletto 4 VD300 / Digiprog 3 / SVCI 2018 / Autel MP808 / Autocom 2020.23 / USBDM / Skyprog / RT809H / R270+
Regards
you need read eeprom................
need help
now my goal is to buy xp-005
who will help?
nezocas (24th January, 2020)
How to do that
I changed one ecu on that type of car.If you have FVDI you can copy the eeprom dump by obd and write it on the new ecu .
Thankīs.... I dont have FVDI
Custumer bougth a brand new ECU 450€ .... more than the value of the car.... but it was itīs choice.
I am in an stand still, dont know if I will build an decoder for this ECUs or buy one from one of the members here in DK
For now problem solved
For only one job isn't worth, but if you work with cars it is worth
nezocas (26th January, 2020)
If FVDI can read eeprom from this ecus with <100 & >100 h/w then not worth it at all
I have found that tool with 80€ but the seller can't confirm that the tool works with h/w under 100....
I have both tool. My fvdi never have problem with thus type of ecu. Fvdi make automatic virgin. Iaw59f tool work also ok but sometimes have problem with <100 hw. Iaw tool is quicker and can make automatic off but i think fvdi is beater cos work on more ecu type's
nezocas (26th January, 2020), Panathaole (27th January, 2020)
