Page 1 of 2 12 LastLast
Results 1 to 15 of 22
    Jun 2019
    EU
    Default BP Symphony PO9898 ( sqr49 BP9898 ) Code
    Hallo , end as the topic ....
    inside is a motorola ZC400257cfn (1c27b )
    whether the connection diagram with HC11 A8/E9 will be correct ?
    Is the code explicit or encrypted ?
    sonices's Avatar
    Jul 2010
    HC11E9 i think , code visible on 78h 79h example 1234
    Why reading motorola? i think it is possible from serial
  3. The Following 3 Users Say Thank You to sonices For This Useful Post:
    audiopoint (26th February, 2020), redzio55 (26th February, 2020), shooting (26th February, 2020)
    Jun 2019
    EU
    Thx , sonices
    I tried after the serial number but without success. Unless you have a better calc ?
    B09898
    sonices's Avatar
    Jul 2010
    For bp9898A-0618745 code is 7625
    But i am confused about B09898 ?
  6. #5
    Jun 2019
    EU
    Someone is already making this radio, so the code is changed. Does anyone have the memory contents for this model ( or approximate ) ?
  7. #6
    Hi!
    Friend! The code for SQR types canot be calculated serial. (unless someone has a database (unlikely)
    You must read the 68HC11 Motorola.
    If the boot process is successful and you only see FF, then HC11 is locked and its contents cannot be read. Then you need to another dump.
    In this case, there is even code off content.
    wbr
  8. The Following User Says Thank You to audio For This Useful Post:
  9. #7
    Jun 2019
    EU
    Hi Audio , that's why I'm asking if anyone will help with dump .
  10. #8
    of course i can give it but you have to read the HC11 first because you can only reprogram it. If you can read it and its content is not FF then decoding is already easy ...
  11. The Following User Says Thank You to audio For This Useful Post:
  12. #9
    Jun 2019
    EU
    ................... is FF , can you help ?
  13. #10
    Hi!
    Try this...
    good luck
    wbr
  14. The Following 2 Users Say Thank You to audio For This Useful Post:
    onkel tom (29th January, 2022), redzio55 (26th February, 2020)
  15. #11
    Jun 2019
    EU
    Thx , but it still displays nothing ...
    Do you have any idea ?
  16. #12
    sonices's Avatar
    Jul 2010
    I found this one but i dont know code
  17. The Following 2 Users Say Thank You to sonices For This Useful Post:
    audio (27th February, 2020), redzio55 (26th February, 2020)
  18. #13
    Raimax's Avatar
    Nov 2013
    LT
    Quote Originally Posted by sonices View Post
    For this serial correct code is 2778
    If you don't like it * close your eyes
    --- Geros dienos ! ---
  19. The Following 2 Users Say Thank You to Raimax For This Useful Post:
    redzio55 (26th February, 2020), shooting (29th January, 2022)
  20. #14
    Raimax's Avatar
    Nov 2013
    LT
    Quote Originally Posted by audio View Post
    Hi!
    wbr
    This is not true
  21. The Following User Says Thank You to Raimax For This Useful Post:
  22. #15
    Jun 2019
    EU
    I'll try tomorrow and let you know....
