Results 1 to 7 of 7
    Aug 2011
    Default Mercedes W210 - won't cranck
    Hi, I have here W210, 2.2d, 2001 year.
    Car has only 1 key. When I insert key esl unlocks, I have full ignition but won't crank. In ecu there is no dtcs, in EZS I have B1056 "fault in CAN communication eith TGS N69/4. In EZS, in "start authorisation data" option I have all checked "yes" and I see 50 terminal ON when I turn key to start position. In ecu "start autorisation data" I have everything checked "NO" so I asume I have something wrong with ECU.
    I tried writing "renew file" with Abrites. The car will crank for 3 seconds 3 times and then it won't crank any more. Any help will be appreciated.
    Regards
    droidwayne65's Avatar
    Aug 2015
    North America
    Post direct reads of EIS and ECU eeproms.
    <---- Coin of the Realm.
    ekas's Avatar
    Jan 2016
    Kyrgyzstan
    Check all status in ezs, both MCU must be ok. Then check can comunicathion between ezs and Ecu, Green White and Green pins. If all ok renew Ecu eeprom and do synchro with star.
    Aug 2011
    Hi, direct readout.
    Regards
    Aug 2015
    North America
    Quote Originally Posted by pipina View Post
    Hi, direct readout.
    Regards
    Well, they belong together but the inner mcu is a mess and there is a sync issue between eis and ecu. Will fix.
    There ya go.
  6. The Following User Says Thank You to droidwayne65 For This Useful Post:
    pipina (27th February, 2020)
  7. #6
    Aug 2011
    Hi, work OK.
    Regards
  8. #7
    Aug 2015
    North America
    Hi, work OK.
    Regards
    Good to hear.
