Page 1 of 3 123 LastLast
Results 1 to 15 of 42
    May 2018
    Cool Mini R50 3K91D HW 09 SW 19 mileage update OBD or on PCB ? Which tool and soft?
    Hi guys,
    I've been going through almost all posts for having a clear understanding for my Mini R50 mileage update and translate from miles to KM on the dashboard with 3K91D mask and HW 09 and SW 19 , but I've not found satisfaction.
    Now that I have a clearer idea I got many questions and hope somone can help me with a clear reply to the different points.
    I have a Mini cooper R50 2003 with a dash in double metrics ( Miles and KM) but mileage display on LCD in miles.
    I want to update the mileage, for that I have a FVDI 2016 and galetto tools and waiting for the shippment of a CarProg, x-prog and R270 tools.
    After trying with the FVDI tool, I've not been able to update mileage as the write function is disabled on the odometer calibration function as you can see it on the picture attached, but I've been able to extract EEPROM file from IKE (Instrument Cluster Electronics) picture attached as well.
    After getting this in hand, I've not found any soft that can't translate the mileage or even tell me at which byte position is the mileage stored.
    So do someone know if I can use this file (attached) to update the mileage and with which soft?
    In case FVDI can't do the job by OBD, can I do it directly with FVDI on board with the different plugs I got with it?
    In case FVDI can't do the job at all, I've ordered CarProg, x-Prog and R270 tools, which one shoold I use and what are the softs you suggest me I need to open the extrated data with?
    May 2017
    Lebanon
    this read isnt full , you need to read mc9s12dg128 mcu on bench with a programmer , xprog or r270 would read it .. post file here ..
    mileage is stored in lines 400 to 470 , your file has only 3F0 ...
    piece of advice: dont trust fvdi too much , its good in many ways but shit in as many ways
    If i was helpful DONT forget the THANKS and REP button
  3. The Following User Says Thank You to Moe1988 For This Useful Post:
    Thealchimiste (16th March, 2020)
    May 2018
    Thanks Moe1988 for your feedback and advice,
    Are mc9s12dg128 and mc912dg128a (mine) µc same?
    Ok, once I get the tools I do extract with pin as shown in the file atteched right?
    May 2018
    Attachment 699548Thanks Moe1988 for your feedback and advice,
  6. The Following User Says Thank You to Thealchimiste For This Useful Post:
    MOBILTRONIC (25th March, 2020)
  7. #5
    Jun 2017
    How far i get whit research to read mcu pin out for xprog is in attachment Screenshot_20200308-144501_Chrome.jpg.
  8. The Following 2 Users Say Thank You to Marens2007 For This Useful Post:
    jcdiag (11th October, 2022), mkii (27th August, 2021)
  9. #6
    Jun 2017
    I mange to read dash eeprom .
    But my knowledge is to short to change vin or milage .
    How fare im understand vin change is not only in hex ��
  10. #7
    Dec 2015
    need change also BODY ECU - c76 or motorola MCU
  11. #8
    May 2013
    If you don't wont have problems with this dash / with 3K91D/ don't try with chines shits !! R270 is not good for this dash!
    Use original programers only!
  12. The Following User Says Thank You to gencho5 For This Useful Post:
    narkeleptk (1st April, 2020)
  13. #9
    Jun 2017
    If i change bsi and Motorola chip in dash will new speedo work for car ?
  14. #10
    May 2013
    yes, if you change Motorola chip in dash new speedo work in car.
  15. The Following User Says Thank You to gencho5 For This Useful Post:
    Marens2007 (18th March, 2020)
  16. #11
    Feb 2020
    UK
    It's mc912dg128a on MINI KMB, mileage it stored on area mentioned above but is also a pair of bytes within the flash that count also (mean can count anything from 0-255 without changing flash area, usually is close enough however to change just EEPROM area itself and is a counting hexadecimal matrix. All entries are summed together and as count goes up next higher byte is injected into start of matrix area and process goes on). I made a matrix counter in excel which can do the job, so feel free to upload the 2KB here and the amount of KM required. I won't share this formula because not one person helped me figure this stuff out on here. Can change also the whole VIN area, I tested last night but nobody help me with that either but I will offer to make a change for part of the VIN for you which is enough for good functioning.
  17. #12
    Jun 2017
    Quote Originally Posted by Wod View Post
    can we try vin change please ??
    vin from car WMWRC32020TC11230
    Car is mini cooper r50 , dash mask 0k50e ,tool xprog
    Thank you
  18. #13
    Sep 2009
    Fr
    Hi you can use fvdi change id on dash or tool32.
  19. #14
    Jun 2017
    Quote Originally Posted by Freezzby View Post
    Not working with fvdi .
  20. #15
    Sep 2009
    Fr
    Did you test it ? I changed vin with fvdi on a mini 3k91d and error gone about id .
    Perhaps on 0k50e don't work.
