Results 1 to 8 of 8
    Jun 2014
    Serbia
    Default Ford Transit 2.2 ecu dump st10f276
    Please I need full ecu dump (flash+eprom st10f276) from boot mode for ford transit 2.2
    9DDM 6C11-12A650 AN
    Thanks in advance!
    Prichyndel's Avatar
    May 2012
    UK
    There u go mate,don't forget to code injectors
    br.
  3. The Following User Says Thank You to Prichyndel For This Useful Post:
    Cesarec (28th April, 2020)
    Jun 2014
    Serbia
    Does anybody have good dump for this ecu. Please I need dump from boot mode, not from obd reading.
    Jun 2014
    Serbia
    Quote Originally Posted by Prichyndel View Post
    br.
    Thanks mate but please read carefully what I write. I need dump from boot mode not obd.
  6. The Following User Says Thank You to Cesarec For This Useful Post:
    Prichyndel (2nd May, 2020)
  7. #5
    Jun 2016
    readed bdm via CGIII-100
  8. The Following User Says Thank You to pawel7924 For This Useful Post:
    Cesarec (3rd May, 2020)
  9. #6
    Jun 2014
    Serbia
    Quote Originally Posted by pawel7924 View Post
    Thanks but I need BOOT reading DCU102. Please read post 1, 3 and 4.
  10. #7
    Jun 2016
    this is boot reading - full dump of this dcu (on photo you have dcu101)
  11. #8
    Nov 2011
    Quote Originally Posted by Cesarec View Post
    wHIch tool (and connection) you use to read FULL dump from ST10F276 ??
