Results 1 to 11 of 11
    Mar 2018
    Romania
    Default Carprog MCU Reflash problem
    Hi. I tried to reprogram my carprog, but without succes.
    The first time I removed the memory from the board. Then I reset the MCU with pin 55 to + 3.3v for 20 seconds. After I connected pin 55 to GND. When I click detect, it does not find it.(I use J-link v8)
    Can someone help me? I have attached some images with the connections. Thanks !
    sergei5005's Avatar
    Nov 2012
    Bs As
    Rremember use the very short wires for conect. Max 6 Cm.
  3. The Following 2 Users Say Thank You to sergei5005 For This Useful Post:
    Col19 (8th March, 2021), lovinedi03 (18th May, 2020)
    electronistul21's Avatar
    Nov 2011
    galati,romania
    it doesn't matter how long the wires are.leave more time connected to 3.3V, the reset can take more than 20 seconds.when you try to connect to the processor, pin 55 must be disconnected, only after you finish programming you put it to GND.
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
  5. The Following 2 Users Say Thank You to electronistul21 For This Useful Post:
  6. #4
    Mar 2018
    Romania
    Quote Originally Posted by electronistul21 View Post
    I sent PM.
  7. #5
    Aug 2008
    your soldering doesnt look too good
    put some flux on and resolder
  8. The Following 2 Users Say Thank You to tango For This Useful Post:
  9. #6
    Jul 2016
    can I please ask for purpose reflashing MCU?
  10. #7
    sergei5005's Avatar
    Nov 2012
    Bs As
    "can I please ask for purpose reflashing MCU?"
    Because Car prog have one internal uses counter,and uses is = 0 not found more. With reflash MCU ,the uses counter is reset and carprog found again.
  11. #8
    Aug 2008
    Quote Originally Posted by jvinhj240 View Post
    alot of carprogs are bought with very old firmware and everyone wants the carprog with at least fw 8 inside therefore reflashing with fw8 dump makes it better
  12. #9
    Feb 2021
    Quote Originally Posted by tango View Post
    do you have fw 8 dump file?
  13. #10
    Aug 2008
    yes i have it so does everyone else more or less
    it is on every forum on the internet
  14. #11
    Junior Member Olsak's Avatar
    Jun 2018
    A
    PLEASE NOT CONNECT USB MY jTAG
