Results 1 to 15 of 15
Thread: W447 2015 dash
    Mar 2010
    Timisoara
    Default W447 2015 dash
    Hello
    read eep from dash on OBD
    ori km is 355364
    i wold need 165000
    Thank you
    Nicolas9's Avatar
    Feb 2017
    Aruba
    your file is not good..
    remove dash. desolder eeprom.
    read again, upload here.
    NO Selling Please !!
    Mar 2010
    Timisoara
    this is dash without eep, MCU 70F3525
    Sep 2013
    ES
    brother dismantle dash and take a 95640, upload file and I modify you
    Mar 2010
    Timisoara
    Quote Originally Posted by Manuelgb View Post
    this is without eep Dashboards VDO on MCU 70F3525
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Quote Originally Posted by clauberty View Post
    Hello
    ori km is 355364
    i wold need 165000
    Thank you
    Report...............
  7. The Following 2 Users Say Thank You to jomberykaso For This Useful Post:
    clauberty (28th May, 2020), Nicolas9 (28th May, 2020)
  8. #7
    Mar 2010
    Timisoara
    attached are ori and after file
  9. #8
    Sep 2013
    I don't think so. Original mileage is still present in your edited file. You can confirm what i'm talking about if you compare with my edition.
    I think mileage is located in line 0C82 (65 3E 1E 02)
    65 3E 1E 02 inverted is 02 1E 3E 65, if you convert this code to Decimal is 35536485, then the result is divided by 100, 35536485/100 = 355364,85 (355.364 kms)
  10. The Following 2 Users Say Thank You to jomberykaso For This Useful Post:
    clauberty (28th May, 2020), kevfield (31st May, 2020)
  11. #9
    Aug 2016
    EURO-KOLCHOZ
    what about can blocker?>
  12. #10
    Mar 2010
    Timisoara
    Quote Originally Posted by jetronic30 View Post
    mounted in the dash
  13. #11
    Mar 2010
    Timisoara
    Quote Originally Posted by jomberykaso View Post
    i will check this tomorrow
  14. #12
    Aug 2016
    EURO-KOLCHOZ
    mounted in the dash
    can you share can blocker connection ?
  15. #13
    Feb 2017
    Baltic
    Cluster plug on cluster side has numbered pins.
    PIN1 - GND
    PIN4 - 12V
    PIN12 - CAN L
    PIN13 - CAN H
    Use multimeter to find suitable points in dash.
  16. #14
    Aug 2016
    EURO-KOLCHOZ
    Quote Originally Posted by mikkhh View Post
    PIN1 - GND
    PIN4 - 12V
    PIN12 - CAN L
    PIN13 - CAN H
    so just like in older Mercedes..
  17. #15
    Apr 2010
    Portugal
    After edit and install CAN filter it stays equal... no luck.
