Results 1 to 6 of 6
    Mar 2010
    GB
    Default iveco EDC17cp52 0281030092 immo off
    Dears , i need to do immo off to this ecu , this is after 2014 i tried many softwares without success i attached the eeprom and flash , i can pay for the solution
    Jan 2018
    Jemen
    Only try to use mpc. If it doesn't work, put e2p.
    FILE SERVICE 24/7
    Stage 1 / 2 / 3 - DPF / FAP / EGR / SCR / NOx / TVA .. etc
    Tools-Master: Autotuner / Flex / Trasdata / IO-Terminal / Launch Euro TAB II
    Genuine software: WinOLS, ECM , tuning software etc ...
    TECHSIX.NET - PLEASE BE CAREFUL THIS SCAMMER !!!!
    http://www.techsix.net/
  3. The Following User Says Thank You to oliva For This Useful Post:
    zecozc (11th August, 2020)
    Mar 2010
    GB
    NOT Working , this solution is like the one i have got from https://www.weboctopus.nl/edc17-med17-immo-off.php
    this ecu is different
    chrissysnaith's Avatar
    Apr 2019
    north east uk
    may need to correct cs in flash before writing
  6. The Following User Says Thank You to chrissysnaith For This Useful Post:
  7. #5
    Mar 2010
    GB
    thank you , i will test and inform you
  8. #6
    Apr 2010
    Do you have news...??
