Results 1 to 8 of 8
    May 2014
    Default Ducato 9DF mileage
    Hi.
    Can someone help calculate mileage?
    Fiat ducato 9DF 52141506 eeprom 95128
    My soft cant recognize this new soft.
    Ori 40649
    new 19649
    Regards
    Team dz's Avatar
    Apr 2017
    ALGERIA
    here file Ducato
    DPF / FAP / EGR / SCR / NOx / TVA FLAP .. etc
    Do not forget to press the button thanks and reputation
    # Algerian #
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Here other option if you want to test it.
    May 2014
    Still 40649...
    I tried both files.
    eprommazza's Avatar
    Quote Originally Posted by rafalgt View Post
    Still 40649...
    I tried both files.
    if you want test it.....problem is the chksum
    professional chiptuning and electronic car repair...four-DynoRace_ wheel_ dynamometer
    156alfa's Avatar
    Feb 2012
    greetings from italy
    hello friend
    it is not a crc problem and a problem of many present positions
    and this can only be solved if there is a response
    exact to detail a suitable tester
    but many people don't want to understand that there are a lot of parameters that no current SOFTWARE can solve the problem
    these ecus often change the position of the parameters
    there are also a couple of overspeeds on the file
    mail the tester's result and I'll give you the file
    Greetings from Italy
  7. The Following 3 Users Say Thank You to 156alfa For This Useful Post:
    ampibali (23rd June, 2021), james44000 (30th October, 2020), jomberykaso (30th October, 2020)
  8. #7
    death9891's Avatar
    Jan 2010
    E.U.
    Hello, can you help with kilometers ducato edc 9DF needs 291220km
    is 623410km
    the rest of the items in the attachment Regards
    OK done
  9. #8
    Sep 2009
    Italia
    Quote Originally Posted by death9891 View Post
    is 623410km
    OK done
    Send eeprom
