Results 1 to 10 of 10
    Sep 2009
    Default 2012 iveco daily remote issue
    Just programmed 2 keys to a 2012 iveco daily with marelli bsi 95640 eeprom. Did the job by programmer using IM508 both keys start the van but remote locking not working. Does remote need programming separately?
    Sent from my SM-N960F using Tapatalk
    Don't forget to hit thanks button
    Mar 2018
    Quote Originally Posted by javyb View Post
    hello, the remote control transponder is encoded at the same time. The keys you use may be the problem. It must be Marelli.
    Sep 2009
    Quote Originally Posted by musti418 View Post
    I have used marelli keys. That's whats getting me
    Jun 2012
    wrong pcb - use with 8 pin smd
    Iveco only.
  5. The Following User Says Thank You to greyg For This Useful Post:
    javyb (15th June, 2021)
  6. #5
    Sep 2009
    Quote Originally Posted by greyg View Post
    Would a Xhorse or Keydiy multifunction remote work?
  7. #6
    Feb 2014
    A little late but yes - KEYDIY generated remote works perfectly on these. Aftermarket chinese keys don't work unless you transfer your dump to the AVDI FIAT key maker and choose the correct chip leg number.
  8. #7
    p1et's Avatar
    Oct 2013
    keydiy will stop working shortly
  9. The Following 4 Users Say Thank You to p1et For This Useful Post:
    Ecuprog31 (6th February, 2022), jodge (6th February, 2022), musti418 (6th February, 2022), Weasel3 (5th February, 2022)
  10. #8
    Feb 2014
    Really? I could not find any such complaint in the KD feedback or the KD forum. I really hope it has been updated and fixed recently...
    What about Xhorse remotes - they also support it. Do you have any observations on their solution too?
  11. #9
    Ecuprog31's Avatar
    Mar 2018
    ive made one kd and one xhorse for Boxer id46 and customer come back after 2 days
    remote stop working and the van don’t start
    i programmed id46 mareli and it’s ok
  12. The Following User Says Thank You to Ecuprog31 For This Useful Post:
    autoTkey (7th February, 2022)
  13. #10
    May 2020
    Quote Originally Posted by p1et View Post
    I actually had a customer return with Ducato after a few days. I thought it was vehicle related since the original sopped working as well, and that was the reason I did a new Keydiy one. This means that it is definitely KeyDiy key related.
    Thanks for sharing this info.
