Results 1 to 7 of 7
Thread: Merc EIS DEAD
    Feb 2018
    Default Merc EIS DEAD
    Hi guys done a spare key on a Merc w211 e class 2003 today, so read eeprom and flash using vvdi prog with adaptor, made the key with vvdimb re fitted and completely dead, so got another switch and wrote the eeprom, car now starts but displays taxi, esp and Srs faults on the dash 🤷🏽~♂️ Any advice please I’m at a dead end now
    Mar 2018
    UK
    You must use exactly the same model EIS to be sure that is compatible
    Feb 2018
    Hi what numbers do I need to match up?
    I matched the part number : 2115450608 and the board is hc12
    p1et's Avatar
    Oct 2013
    Post eeprom and flash from original EIS
    fred77's Avatar
    Jun 2019
    flashes normally same I've, as many others had odd occasion something gone wrong.
    Load eeprom dump into EZS calc and it'll check
    Solidarity with Ukraine
    Jan 2017
    Netherlands
    You sure you have exactly the same number and did you also program the coding in?
    Sep 2015
    Botswana
    Did you get help with eis
