Results 1 to 15 of 17
    EASTERN AFRICA
    Default kyron immo off dcm3.2ap
    hello
    Could anyone help me to disable immo in ssangyong kyron ecu delphi DCM3.2AP A655 540 84 32 27DT?
    Thank you very much
    Jul 2019
    far far away
    give this a go and report
    clear your inbox for pass
  3. The Following User Says Thank You to alpntrb For This Useful Post:
    sokolomo (29th April, 2022)
    EASTERN AFRICA
    could you give me pass please? thank's
    EASTERN AFRICA
    car start but throttle doesn' t respond, dtc cannot erase,
    P0630 variant coding is not done,
    P0602 ecu program fault
    P0631 variant coding writing error
    P0619 multi calibration performing error
    P0611 inj control module performance
    help please
    rafal's Avatar
    UK - PL
    Quote Originally Posted by sokolomo View Post
    help please
    then write this one...................
    need help
    now my goal is to buy xp-005
    who will help?
  7. The Following 2 Users Say Thank You to rafal For This Useful Post:
    lion0304 (29th April, 2022), sokolomo (30th April, 2022)
  8. #6
    EASTERN AFRICA
    pass please
  9. #7
    EASTERN AFRICA
    Quote Originally Posted by rafal View Post
    Pass not yet received
  10. #8
    rafal's Avatar
    UK - PL
    sent...............sorry for delay
    need help
    who will help?
  11. #9
    EASTERN AFRICA
    sorry for delay car is far from me, tested file and always same problem, engine speed don't exceed 1200rev/mn, what is wrong? is there a procedure to follow? any idea please
  12. #10
    Nov 2017
    Dobruja
    Did you disconnect immo box?
    Best way was delete all dtcs before taking ecu apart from the car, then write immo off eprom, better with write protect. Remove immo box, connect the ecu and battery and start the car. Should work. Of course, if immo off was propperly made.
    Btw, check if AC works after immo off
  13. The Following User Says Thank You to volodin69 For This Useful Post:
    sokolomo (25th May, 2022)
  14. #11
    Apr 2022
    i have solution work without error
    ......................your car star????
  15. #12
    EASTERN AFRICA
    Quote Originally Posted by all4 View Post
    ??car start but don't accelerate, could you share your solution please
  16. #13
    EASTERN AFRICA
    Quote Originally Posted by volodin69 View Post
    maybe I'm wrong, immo box is connected to the reading coil of the starter switch? is it exact or not
  17. #14
    EASTERN AFRICA
    sorry immo box is the box connected to ignition switch read coil?
  18. #15
    lion0304's Avatar
    Oct 2014
    If you don't know how to work with immo OFF, don't blame solution.
    Does file is original from car or someone already modified before? Coil must disconnected.
