I have a Vespa motor and the key is to lose
I have read the dump ST10F269 144 pin gave a straightforward solution that can be programmed or transplonder to immo off
Vespa 250
5x80fux8g
cm078201
32 mIu1.e0
Vespa 250
5x80fux8g
cm078201
32 mIu1.e0
Device: ST10F269-T3 - 144 pin TQFP
256/262144/327680
i do by hand i do not have programmer it must be
5f 00 00 8d d2 80 56 7d key 1
5f 00 00 af 82 80 56 7d key 2
if not work try swap
like
key 1 5f 00 00 d2 8d 80 56 7d you will find it not worry
Geekey (18th November, 2020)
auto_russia (1st April, 2013), Geekey (18th November, 2020), lion0304 (13th April, 2015), motorbike59 (21st November, 2020)
Thank you thank you thank you "gepakg" This combination is ok ...., But thanks to the "gadroulll" without you this would not able to solve
Hello!Can anyone help with this file I need to program key for Piaggio MP3.Thanks
Piagio dump
Is there any solution to make virgin ECU or immo...
piagio bevery moto.rar
pls. help me transponder temic 11
ok
works perfectly
strong
How did you read ST10F269?
Did you desolder or have pinout?
hi mates,
I have piagio x7 125cc with immo problem. I have one key and I think it is ok but bike no work. Can anyone help me with immo off or other solution?
Thanks in advance
Hello
please write this dump and start to moto with org. key
alclot (19th November, 2018)
