Page 929 of 1262 FirstFirst ... 4298298799199249259269279289299309319329339349399791029 ... LastLast
Results 13,921 to 13,935 of 18929
  1. #13921
    Nov 2019
    i need little more power,egr off and hardc cut popcorn at 4500 rpm
    there is my file readed with kess
    hw : 0281011411
    sw: 1037361859
    file :
  2. #13922
    Nov 2010
    Default x6 35d 286ps
  3. #13923
    aby23's Avatar
    Mar 2019
    Romania
    Quote Originally Posted by lanix View Post
    https://mega.nz/file/V1wGQSbB
    https://mega.nz/file/ksxGzCgK
    if you want your tuning file, post your file with the password or delete password
  4. #13924
    Junior Member zazer's Avatar
    Apr 2019
    hello everyone i need stage 1 + popcorn limiter for my audi 2.0 tdi BPW dpf removed
  5. #13925
    Nov 2010
  6. #13926
    Jul 2013
    Default 2010 Audi 3.0 TDI CR 240 (CDYA engine code)
    Stage 1 tune please, and both swirl flaps actuation delete and swirl flaps error mask.
    Also, is it possible to allow left foot braking without losing boost?
  7. #13927
    Oct 2010
    Bucharest
    2013_Peugeot_308_1.6_cmc_EDC17C10_Stage_1
    Hello,
    Stage 1 tune please, PSA_EDC17C10_9666077280_9666729580_9679172880 .
    Peugeot_308
    2013
    1.6 cmc
    92CP
    HW: 9666077280
    SW: 9666729580
    SW upg.: 9679172880
    Thank you.
    Best Regards .
  8. #13928
    Aug 2020
    Default DCM3.5 C5 X7 163KM RHH RH02 - EGR OFF
    Will you validate the existing stage 1. Please help me turn off EGR. Citroen C5 X7 2010 RHH 163KM. AM6 gearbox. Thanks
  9. #13929
    Aug 2020
    ciao for citroen peugeot fiat 2.0 turbo bosch motronic mp.3.2 eprom 27c256 0261200219 ecu this is file to tuning and optimizing
  10. #13930
    Aug 2020
    Default ecu file original
    this is file
  11. #13931
    Jul 2020
    Post
    hello! Could anyone do stage 1 for me.Car a4 b7 1.9 tdi BRD no dpf. Thanks in advance. Best regards
  12. #13932
    May 2015
    Default REMOVE DTC SANYONG DELPHI 2.0 104KW
    ID
    HW: 72702804
    SW: HCD35A10
    P0400
    P1115
    P1149
    I NEED REMOVE THIS IS IMPOSIBLE FOR ME WHIT DTC REMOVER
    The ecu is delphi dcm engine Mercedes
    Thanks bros!
  13. #13933
    Oct 2013
    Quote Originally Posted by swiftfix View Post
    hi can anyone help with a file on a iveco daily 35s11 2012 2.3 edc17
    max safe power and remove speed limiter
    thanks in advance
    can anyone help please
  14. #13934
    Aug 2020
    Awesome Forum, I have some files to share and I need some help with IMMO and ECU Errorst. Glad to have found this diamond
  15. #13935
    Apr 2020
    Quote Originally Posted by userkare View Post
    file for you, pass PM
    dont forget press thanks and reputation button
  16. The Following User Says Thank You to ZiZiTun For This Useful Post:
    userkare (12th August, 2020)
