Results 1 to 9 of 9
    Dec 2017
    espaņa
    Default I Need DTC OFF P0380 EDC15C2
    Hi all. I need to delete DTC P0380 please have tried and can not find it. I send you EGROFF File to see if you can do it. Thank you very much and greetings.
    Citroen Xsara Picasso 2.0 HDI Ecu EDC15C2
    Aug 2018
    Russian Federation
    no EGR no DTC
  3. The Following User Says Thank You to QuantumECU For This Useful Post:
    chipcarcordoba2 (18th January, 2019)
    Dec 2017
    espaņa
    thanks, no P0380? ok, i try...
    Dec 2017
    espaņa
    pass, please
  6. #5
    Dec 2017
    espaņa
    thanks... no free, someone who can help me for free? please...
  7. #6
    bobolin4o's Avatar
    Apr 2010
    Bulgaria, V. Tarnovo
    Quote Originally Posted by chipcarcordoba2 View Post
    Have you some indication in the dash about this DTC (P0380)?
    AND POST ORIGINAL FILE FROM THIS ECU!!!
    NO PASSWORDS FOR ANYONE, EXCEPT THE RECIPIENT OF THE FILE !!!
    If your PM box is full, clean it right now...
    Otherwise, your requested file will be deleted... for ever!
  8. The Following User Says Thank You to bobolin4o For This Useful Post:
  9. #7
    Dec 2017
    espaņa
    thanks, engine failure appears. and I can only remove that DTC.
  10. #8
    bobolin4o's Avatar
    Apr 2010
    Here is your file.
  11. The Following User Says Thank You to bobolin4o For This Useful Post:
  12. #9
    DK Veteran germanml's Avatar
    Sep 2011
    spain
    hello friend, please I have same ECU, could you please give me Pass???
    regards
