Results 1 to 13 of 13
    tazz75's Avatar
    Nov 2018
    Default Alfa Romeo 159 JTDm
    Hy i need full bdm or bdm files for this Ecu
    Or information abaout sw version wich i need
    Was swap the ecu with same Bosch number but i can't align ESP in new Ecu
    Or someone maybe can help with this error
    TRW Lucas ABS (ESP) C1103 - Configuration changed
    Thx in advance
    macinek102's Avatar
    Feb 2019
    PL
    1.What engine?
    2.Why did you change the ECU?
    3. Have you tried proxi alignment by MES or ALFAOBD?
    4. Has anyone ever changed Body Comp or ABS?
    If I helped, press the Magic Button
    tazz75's Avatar
    Nov 2018
    1.9 diesel engine
    was tryed with MES registeered..and AlfaObd too
    Orig Ecu is watter damaged..i have and i can read only eprom from older Ecu
    No one was changed anithing on this car ..
    Thx
    tazz75's Avatar
    Nov 2018
    This one is manual transmission..and i think de second ecu has automatic ..and of course another Abs Ecu
    Was readed something in other forums abaout this error..they say i need edc16 damos file and change something ..MDNORM..and of course i have no clue in this things
    macinek102's Avatar
    Feb 2019
    PL
    are the photos from the damaged driver? Can you read the number HW 0 281 ...... from the controller housing?
    tazz75's Avatar
    Nov 2018
    Yes is this the damaged one..i can make photo abt new one..but i remember is same 100%
    tazz75's Avatar
    Nov 2018
    This is second one ...
    115jtd's Avatar
    Mar 2019
    Do you have sw number 1037 38xxxx
  9. The Following User Says Thank You to 115jtd For This Useful Post:
    tazz75 (31st May, 2020)
  10. #9
    tazz75's Avatar
    Nov 2018
    Thx..will try to find somwhere
  11. #10
    115jtd's Avatar
    Mar 2019
  12. The Following User Says Thank You to 115jtd For This Useful Post:
  13. #11
    ASCM's Avatar
    Oct 2018
    Quote Originally Posted by tazz75 View Post
    Write a compatible flash
    Sent from my SM-J415F using Tapatalk
  14. The Following User Says Thank You to ASCM For This Useful Post:
  15. #12
    tazz75's Avatar
    Nov 2018
    Quote Originally Posted by 115jtd View Post
    Yes..i know that ..i found 2 files until now Thx a lot for info..
  16. #13
    Apr 2022
    I solved the problem, also cloning the ecu
