Page 1 of 2 12 LastLast
Results 1 to 15 of 19
    Dec 2016
    Default Aprilia dorsoduro 900 ghange km
    Aprilia dorsoduro 2018 24C512
    carent 16451 km
    need 2232 km
    Please.
    Jan 2010
    Trstenik - Thun
    Quote Originally Posted by viytik1 View Post
    carent 16451 km
    need 2232 km
    Please.
    never have this model before but if you want you check this ....................
    PM for Pass
  3. The Following User Says Thank You to mikroel For This Useful Post:
    hoangtu (25th September, 2021)
    Dec 2016
    No pass PM.
    Jan 2010
    Trstenik - Thun
    No pass PM.
    "PM for PASS" means :Ask for PASS by sending Private Message and then you will get PASS on Private Message
    anyway i sent Pass to you
    Try and report
  6. The Following 2 Users Say Thank You to mikroel For This Useful Post:
    PremierD (23rd September, 2021), viytik1 (23rd September, 2021)
  7. #5
    gogalv's Avatar
    Aug 2010
    If you eat without CS dumps, you can not even try, and not waste time.
    You'll need pictures from all sides mate .... ? PremierD
  8. #6
    Moderator
    PremierD's Avatar
    Jun 2009
    kms *10 repeated numerous times ...........but cannot be that simple surely
  9. #7
    Dec 2016
    Showing the old mileage.
  10. #8
    Jan 2010
    Trstenik - Thun
    ok here is new improved ...same pass
  11. The Following User Says Thank You to mikroel For This Useful Post:
    impolis (1st March, 2023)
  12. #9
    Jun 2016
    Budapest HUNGARY
    carent 16451 km
    need 2232 km
    Please.
    checksum simple add type only no 8bit.add
  13. #10
    Dufner
    Johnner's Avatar
    Jun 2010
    Éire
    Quote Originally Posted by f2f2 View Post
    SO, if I read this right : It's a summator CS = 02+82+a0 = 124, drop the MSB = 24 ?
    34x instances
  14. The Following 3 Users Say Thank You to Johnner For This Useful Post:
    frankrayk (25th September, 2021), neospeedo (25th September, 2021), PremierD (25th September, 2021)
  15. #11
    Jun 2016
    Budapest HUNGARY
    Quote Originally Posted by Johnner View Post
    34x instances
    Cs 4 item
    A B C D
    byte 1-16
    Add 4 bswap integer
    this simple
  16. The Following 4 Users Say Thank You to f2f2 For This Useful Post:
    frankrayk (25th September, 2021), hoangtu (25th September, 2021), Johnner (25th September, 2021), PremierD (25th September, 2021)
  17. #12
    Dufner
    Johnner's Avatar
    Jun 2010
    Éire
    That's great info mate, you just gave there.
    I looked at this, and can see some inconsistencies in there
    Some of the summations are adding the overflow bit back into the LSB, and some are not
    eg, 45 64 74 24 00 02 d5 da 00 02 82 a0 00 00 00 00
    45 69 cc 9e
    45+00+00+00=45
    64+02+02+00=68
    74+d5+82+00=1cb=cb+1=cc
    24+da+a0+00=19e
  18. The Following User Says Thank You to Johnner For This Useful Post:
    Cllau (26th September, 2021)
  19. #13
    Jun 2016
    Budapest HUNGARY
    45 69 cc 9e
    45+00+00+00=45
    64+02+02+00=68
    24+da+a0+00=19e
    I bad write on DK
    no separated add
    add32
    integer byte sorting
    i= block address!
    a = 0
    For i1 = i To i + 14 Step 4
    /* */ a = Add(a, Bswap(Int{V:dd + i1}))
    Next i1
    Int{V:dd + i + 16}=Bswap(a) //Write Checksum
    bytes and bits : 45 64 74 24 24-31bits 16-23bits 8-15bits 0-7bits
    Add(0x45647424, 0x0002d5da, 0x000282a0, 0x00000000) = 0x4569cc9e
  20. The Following User Says Thank You to f2f2 For This Useful Post:
    Johnner (28th September, 2021)
  21. #14
    gogalv's Avatar
    Aug 2010
    The bike has been riding with new km for a long time, and you are engaged in school mathematics.
  22. #15
    Jun 2016
    Budapest HUNGARY
    Quote Originally Posted by gogalv View Post
    Only for Johnner
    I write bad now correction.
    No school.
  23. The Following 4 Users Say Thank You to f2f2 For This Useful Post:
    drpeter (28th September, 2021), Johnner (28th September, 2021), PremierD (28th September, 2021), volodin69 (28th September, 2021)
