Page 1 of 2 12 LastLast
Results 1 to 15 of 27
    Nov 2009
    Default BIG PROBLEM WITH A4 TDI
    HI
    I have a very big problem with A4 TDI 2.5 TDI 163CV.
    When i have reprog ecu with galeto , my pc has bug.
    Since the car don't start, the fan work any time.
    How i can restart the car?????????
    Nov 2009
    Morocco
    try boot mode
    Nov 2009
    HOW
    Could explain me, please?
    Aug 2009
    Netherlands
    Try to flash it on the table, see attached docu.
    Otherwise remove the flash and use a programmer.
    Aug 2009
    Quote Originally Posted by SIMCAR2 View Post
    HI
    Desolder.
    Regards.
    Nov 2009
    serbia
    i think you must open the ecu
    read the memory and program it with original dump
    it should be works
    DK Veteran rsibiza's Avatar
    HI
    Hi.
    As i know, a starting Fan is showing ECU is death.
    Fan is Ground controlled by ECU,and errors during writing can destroy ECU's.
    A Friend of me had this with a R32 ME7.1.1,this ECU can only be flashed by byteshooter with pull up resistor,or at table adding an resistor between some pins of 29F800,he did it usin MPPS on diagnostic.
    After write failed,Fan startet.
    Desoldered and replace 29F800,but no change,reflashed it and no change.....
    I think you have same case.sorry
    Best regards.
    Senior Member drivergabriel's Avatar
    Aug 2009
    BUCURESTI
    1:dismont ecu, program-it on the bench with original flash. the car will start!
    2rogram-it with ,,tunned'' file on the bench (bdm100). older but best solution.
    3:this are result of ,,chineese'' tools..
    Nov 2009
    next week, i try to reprog flash directly and i post result.
    Quote Originally Posted by drivergabriel View Post
    3. Is correct,but a bad flashed 29f800 will not do start the fan.
    I dont believe it will work,
    But i hope for you it woeks. Can you please post here result?
  11. #11
    Dec 2009
    Bulgaria ,Plovdiv 4000
    Yes,will start fans if ecu is empty.Open the ecu and desolder the flash.Hope you read the data before try to write new one?
    If you have not ,write me pm with ecu ID and will send you ori.
    Ecu location is -left side near to wiper-will need to remouve lft wiper to open the black box
  12. #12
    Nov 2009
    OK
    But i don't have programmer for this eprom.
    I post result when i have solution for program this.
  13. #13
    Serial programming tools will not recognise ecu,same as cloned galetto as original geletto will not recognise it.
    The BDM100 is also the chinese name for a shitty cloned cmd flasher,because real BDM100 is designed for EDC16 ecu s not edc15,so it would not work on this ecu
  14. #14
    electromech's Avatar
    Dec 2009
    Behind a large rock
    Just a thought I got away with this a few times but not with this car . basically get another car like this and go in the system and prep vehicle for reprogramming and just as it is about to reprogramme swop ecus and program once it has sofware on it then you can reprogram properly to your vehicle eg vin,tune..........I am not saying it will work but it is worth a shot!!!
    Fcuk up now............... ask questions later
  15. #15
    Nov 2009
    PROBLEM SOLVED
    I have reprog 29F800 with programmer and car start.....
