Results 1 to 5 of 5
    Mar 2020
    Default 2010 Cadillac Escalade SuperNav TheftLock EEPROM
    I have 2010 Cadillac Escalade and a used radio that I bought from a part store(Already has a VIN programmed that doesn't match the BCM), and an old not working radio.
    Part Number: 20955278
    I installed the new radio with a replacement and I'm greeted with the TheftLock error due to the VIN's not matching.
    I was going to copy the EEPROM from the old radio to flash on the working used radio, but I have it apart and cannot find the EEPROM location on this board.
    I've found one chip labeled "28033204" from searching appears to be a 24C256 chip.
    I have a dump and searched through it, it does have a string of numbers but it doesn't look like the VIN number, which makes me think this isn't where the VIN is stored. (I've attached the dump just in-case I'm wrong)
    TL;DR
    Does anyone know where the EEPROM where the VIN is stored on this radio!?
    I appreciate any help
    (I've also attempted to take it to 3 Cadillac dealer to which have been told it's write once and they cannot do a VIN relearn....I then attempted a few mechanics that have Tech2's/MDI's and they also said they couldn't do it .....)
  2. The Following User Says Thank You to veris For This Useful Post:
    andresrepair (12th September, 2021)
  3. #2
    Raimax's Avatar
    Nov 2013
    LT
    Look at the address line 440h
    The last 6 digits of the VIN number are used
    If you don't like it * close your eyes
    --- Geros dienos ! ---
  4. The Following 3 Users Say Thank You to Raimax For This Useful Post:
    clusters (8th April, 2020), TERNOCOD (12th July, 2021), veris (8th April, 2020)
  5. #3
    Mar 2020
    Quote Originally Posted by Raimax View Post
    I changed the digits for the new VIN, and it did work. Thank you so much. I appreciate it!
    Solved
  6. The Following User Says Thank You to veris For This Useful Post:
    dragoshu (7th July, 2021)
  7. #4
    dragoshu's Avatar
    Aug 2016
    Dacia
    Hello,I have costummer with cadillac escalade need to put vin inside of this super navi GM PN:25795337
    Delphi PN:28078955.
    I open but I dont find this eeprom to read ....if sombody have one picture or somthink to help me to find the eeprom ill be apreciate.
    If I help you dont forget to push thanks button
  8. #5
    dragoshu's Avatar
    Aug 2016
    Dacia
    Quote Originally Posted by dragoshu View Post
    Delphi PN:28078955.
    I have found,
    But it not on 440h line last 6 digits of vin.
    it on 810
  9. The Following 3 Users Say Thank You to dragoshu For This Useful Post:
    badbanane (3rd February, 2022), mkopytekchi89 (15th September, 2022)
